32 bit math
Results 1 to 5 of 5
Thread: 32 bit math
    Mar 2006
    Default 32 bit math
    I have to add 2 numbers in a very repetitive sequence.One is 10 bit and the other -where the addition is registered- should be a 32 bit register. Could anyone suggest a subroutine to add these numbers, compatible with PBPro?
    Thanks in advanced
    -Francesc
    Piece of Cake.
    Result  VAR WORD[2]
    Avar    VAR WORD
    Result[0] = Result[0] + Avar
    if Result[0] < Avar then Result[1] = Result[1] + 1
    _
    Quote Originally Posted by fnovau View Post
    Thanks in advanced
    -Francesc
    Upgrade to PBP 2.50a?
    Mar 2006
    Default 32 bit math
    Do you mean I have to upgrade to 2.50a version for using Darrel code? I use Pic16F677 and my PBP is 2.47 version
    No, I only meant that an upgrade to PBP 2.50a includes support for LONG variable types, which are 31 bit signed variables, whereas 2.47 and earlier support WORDs, 16 bit unsigned variables at most.
    And the upgrade is only $25.
    Last Post: - 14th June 2016, 08:55
  2. Averaging 16 bit values without using 32 bit math
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 5th October 2007, 23:18
  3. PIC18Fxx math 24 & 32 bit
    By ronsimpson in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2006, 13:52
  4. 32 bit math
    Last Post: - 28th August 2006, 14:34
