External osc defines
Results 1 to 21 of 21
    Jan 2008
    Selm, Germany
    Question Impossible to compile
    Hi Bruce,
    as I told you your hex code of my small program really works.
    But if I take your previously shown config fuses I get only a compilation error
    ' 16F628A 20Mhz extern canned Oscillator
    ' damn program should blink an LED
    ' Igot that compilation error
    @ __config _EXTCLK_OSC & _WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    LED VAR PORTB.7
    CMCON = 7 ' RA0-RA3 are digital I/O
    TRISB = %01111111 ' RB7 is output, rest are inputs.
    led = 1
    led = 0
    END ' End of program
    Error[118] c:\pic\16f628a\blinkb~2.asm : Overwriting previous address contents (2007)
    when I use only this config:
    I get no comp. error but the thing dosnīt work either.
    is an external Osc. with 20 Mhz a no go for PBP ?
    If you would just please take the time to read this thread http://www.picbasic.co.uk/forum/showthread.php?t=543 you should get what's happening. If not then let me know.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2008
    Selm, Germany
    Talking Took time to read
    Hi Bruce,
    yeeeees I understood and read the whole thread and you were right: there it all stood.
    The most "difficult" part of it was to find out in WHICH of those .INC files the config fuses had to be changed.
    there were at least three of them and 2 were in the PBPDEMO folder and those were the ones but I dunno which of those two. commented the configs in both.
    After that my BLINKBILLIG20MHz blinked way too fast and the "DEFINE osc 20" programming and compiling worked not for the first 4 times although I erased the PIC complete before programming.
    Now it does. And reacts on changing the osc frequency.
    thanks a bundle.
    I guess your nerves get friggled up with guys like me asking the "obvious" for the 20th time, huh?
    next try will be 3 pics with one canned 20Mhz oscillator.....
    Not at all. I enjoy answering questions here because I will almost always learn something in the process, and I enjoy learning. A nice by-product of this is that I get to help someone else in the process of learning new things myself.
    I just see no point in re-typing an answer to a question that has already been thoroughly covered in another thread.
    If someone has taken the time to read information in a thread I linked to, the data sheet, manual, etc, and they still have a question about some part of it they aren't 100% clear on, then I'm more than happy to attempt to elaborate.
    -Bruce
    tech at rentron.com
  1. Internal vs. external osc for comms
    By mtripoli in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 14:58
  2. Replies: 1
    Last Post: - 28th January 2010, 22:15
  3. 18F1320 with external osc
    By Mugelpower in forum mel PIC BASIC Pro
    Last Post: - 12th February 2008, 22:32
  4. How to use an external oscillator
    Last Post: - 5th February 2008, 14:19
  5. External clock
    By Firegod in forum mel PIC BASIC Pro
    Last Post: - 17th March 2007, 00:53
