Pwm
Results 1 to 7 of 7
Thread: Pwm
    Jul 2007
    Default Pwm
    How do I PWM two pins at the same time with this code?
    For duty = 0 to 255
    PWM PORTB.0,Duty,Cycle
    HIGH PORTB.0
    Next
    Sep 2007
    USA, CA
    With the PWM command, you can not.
    Jul 2007
    Is there anyway you can PWM to pins at the same time?
    Sep 2007
    USA, CA
    You can, if you use a PIC with two hardware PWM modules.
    Or, you you use interrupts. Search for Darryl Taylor's "instant interrupt", and you'll find everything you need. (I think a post from just today has it.)
    Sep 2007
    Default Multiple Slow Speed PWM
    Hi XOXB,
    Yes I agree that Darrel's Multiple Slow Speed PWM example is great. I use 16 channels of PWM to control the brightness of LEDs on an 18F2410. I believe you could do 8 or more on a 16F. It all depends on the freq and the resolution you run at. You must use this with DT_INTS-14 or DT_INTS-18 depending on the pic.
    Thanks again Darrel!!!
    DT_INTS-14 (SPWM_INT - Multiple Software PWM)
    http://darreltaylor.com/DT_INTS-14/SPWM.html
    Best Regards,
    Kurt A. Kroh
    KrohTech
    “Goodbye and thanks for all the fish”
    Feb 2003
    Salt Lake City, Utah USA
    Quote Originally Posted by xobx View Post
    Do they need to be at the same frequency?
    Are the duty cycles related (e.g., 1/2 or double of the other)?
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Default This is my code for testing PWM
    ; adjust duty 50%
    ; period of on state ,Tduty
    ; (CCPR2L with T2CON.5.4) = Tduty / (Tosc x T2prescale)
    freq1 con $41 ; adjust for duty cycle
    freq0 con $00 ; very low duty cycle for no output
    ccpr2l = freq1 ; adjust Duty cycle
    ; adjust carrier frequency
    ; period of PWM ,Tpwm
    ; Tpwm = (PR2+1)x(4Tosc) x T2prescale
    pr2 = 130
    ccp2con = %00111111 ;MSB>> 2xNone..2xDuty2bitLSB..4xPWM mode >>LSB
    t2con =%00010000 ; MSB>>1x None..4x PostScale....1xEnable..2xPrescale >>LSB
    tmr2 =$00 ; clear timer2 register
    t2con.2 =1 ; enable timer2 module
    '------------ Variables ---------------
    index1 var byte ; for loop count
    goto test1
    test1:
    ;start freq
    if portb.7=0 then
    ccpr2l =freq1
    ;stop freq
    if portb.6=0 then
    ccpr2l =freq0
    goto test1
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM: Vernacular/Function (Newbee)
    By TerryN in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 17:58
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
