RF Transmitter/Reciver
Results 1 to 40 of 76
    And I will add again.
    A good antenna is a must!
    Jan 2008
    Yes... Now i have get the program to work very well whit inverted mode, tested it at 100 meters and there no errors or missing numbers.
    But then we come to the next problem, I have searched the forum and I find out that iīm not alone whit this problem, but the solution for it doesīt work for me.
    I canīt get the SERIN timeout to work, and yes the input is switching between high and low when the transmitter is off. i have tryed whit an 1K, 3K, 4.7K, 10K resistor between GND and the input pin but when the timeout works the recive module does not and when the reciver work the timeout does not.
    So what else can i do? is there an software solution for this or must i use an hardware solution?
    Could you post your current code? It may be some thing simple that has been over looked.
    Jan 2008
    <html>
    <head></head>
    <body><!--StartFragment--><pre><code><font color="#008000"><i>'****************************************************************
    '*  Name    : Reciver.BAS                                       *
    '*  Author  : Fredrick                                          *
    '*  Notice  : Copyright (c) 2008                                *
    '*  Date    : 2008-02-13                                        *
    '*  Version : 2008-02-16                                        *
    '*  Notes   : PIC16F872 @ 20 MHz                                *
    </i></font>ADCON1 = <font color="#808080">7 </font><font color="#008000"><i>' Alla digitala
    </i></font><font color="#000080">DEFINE </font>OSC <font color="#808080">20
    </font><font color="#000080">DEFINE </font>LCD_COMMANDUS <font color="#808080">3000   </font><font color="#008000"><i>'Set command delay time in us
    </i></font><font color="#000080">DEFINE </font>LCD_DATAUS <font color="#808080">200       </font><font color="#008000"><i>'Set data delay time in us
    </i></font><font color="#000080">DEFINE </font>DEBUG_BAUD <font color="#808080">2400
    </font><font color="#000080">DEFINE </font>DEBUG_MODE <font color="#808080">0
    </font><font color="#000080">DEFINE </font>DEBUG_REG PORTC
    <font color="#000080">DEFINE </font>DEBUG_BIT <font color="#808080">7   </font><font color="#008000"><i>'PORTC.7 OLIMEX RS232Board
    </i></font><font color="#000080">INCLUDE </font><font color="#FF0000">&quot;modedefs.bas&quot;
    </font>ReciverPIN <font color="#000080">VAR </font>PORTC.<font color="#808080">0
    </font>Check1 <font color="#000080">VAR BYTE
    </font>Check2 <font color="#000080">VAR BYTE
    </font>Counter <font color="#000080">VAR BYTE
    </font>Errors <font color="#000080">VAR WORD
    CLEAR
    PAUSE </font><font color="#808080">500
    </font><font color="#000080">LCDOUT </font><font color="#808080">$FE</font>,<font color="#808080">1
    </font>Main:
        <font color="#000080">SERIN </font>ReciverPIN,N2400,<font color="#808080">100</font>,NoSignal,[<font color="#808080">$55</font>,<font color="#808080">$55</font>,<font color="#808080">$55</font>,<font color="#808080">63519</font>],Counter,Check1,Check2
        <font color="#000080">IF </font>Check1 = <font color="#808080">121 </font><font color="#000080">AND </font>Check2 = <font color="#808080">212 </font><font color="#000080">THEN
            GOSUB </font>LCD
        <font color="#000080">ELSE
           GOSUB </font>NoSignal
        <font color="#000080">ENDIF
    GOTO </font>Main
    LCD:
        <font color="#000080">LCDOUT </font><font color="#808080">$FE</font>,<font color="#808080">$80</font>, #Counter, <font color="#FF0000">&quot;    &quot;
        </font><font color="#000080">DEBUG </font>#Counter, <font color="#808080">13</font>,<font color="#808080">10
        </font>Check1 = <font color="#808080">0
        </font>Check2 = <font color="#808080">0
    </font><font color="#000080">GOTO </font>Main
    NoSignal:
        Errors = Errors + <font color="#808080">1
        </font><font color="#000080">LCDOUT </font><font color="#808080">$FE</font>,<font color="#808080">$C0</font>, <font color="#FF0000">&quot;ERROR:&quot;</font>,#Errors,<font color="#FF0000">&quot; &quot;</font>,#Check1,<font color="#FF0000">&quot; &quot;</font>,#Check2
        <font color="#000080">DEBUG </font>#Counter, <font color="#FF0000">&quot;ERROR:&quot;</font>,#Errors,<font color="#FF0000">&quot; &quot;</font>,#Check1,<font color="#FF0000">&quot; &quot;</font>,#Check2, <font color="#808080">13</font>,<font color="#808080">10
    </font></code></pre><!--EndFragment--></body>
    </html>
    USA - Arizona
    Fredrick, what you are seeing is the receiver "wait" loop is being re-triggered continuously by the noise (as you probably know by now). There is no proper way to get the "wait" command to work with software only.
    I would suggest the following (this is a simple way to create your own squelch circuit):
    1. Set the threshold for an RSSI level equivalent to a good signal (above that which you capture noise only). This would give you a cleaner mark-space signal (need to make sure the comparator is high speed).
    2. Output of comparator is "ANDed" with the RX-DATA output and sent to SERIN.
  1. Generic RF Receiver
    By dhouston in forum Code Examples
    Last Post: - 8th September 2009, 15:35
  2. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 13:52
  3. Help with CC1100 RF Modules.
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 27th November 2006, 21:58
  4. RF designs
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 14th June 2006, 08:50
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 23:27
