RF Transmitter/Reciver
Results 1 to 40 of 76
    Jan 2008
    COOL! Whats next?
    I don´t know but now i will try to get this to work better.
    Italy
    From page 3:
    http://www.parallax.com/Portals/0/Do...ceive-v1.0.pdf
    Calibration
    When initiating communication between the RF modules, a sync pulse should be sent
    to re-establish the radio connection between the modules. Sending several characters
    can accomplish this, however sending a pulse (which maintains a high state during the
    synchronization) is more efficient.
    See page 6 for the BS2 code samples.
    RSSI PIN (Received Signal Strength Indicator)
    This line will supply an analog voltage that is proportional
    to the strength of the received signal.
    Can you test that and post the results?
    (Do not connect the PIC microcontrollers during this test).
    Step 1: Connect a digital voltmeter to the RSSI PIN of the receiver.
    (Make sure the multimeter is set to DC volt and that you measure from the RSSI PIN to GND).
    Power on the receiver and make sure the transmitter is powered off.
    Q1: What voltage do you get on the RSSI PIN of the receiver?
    Step 2: Power on the transmitter.
    Q2: What voltage do you get on the RSSI PIN of the receiver?
    (The transmitter and the Receiver are powered on).
    Step 3: Connect +5V via a 1k ohm series resistor to the DATA pin of the transmitter.
    (The transmitter and the receiver are powered on).
    Q3: What voltage do you get on the RSSI PIN of the receiver?
    Step 4: Connect GND via a 1k ohm series resistor to the DATA pin of the transmitter.
    Q4: What voltage do you get on the RSSI PIN of the receiver?
    Best regards,
    Luciano
    EDIT:
    These are the RF modules used by Parallax:
    LR Series RF Transmitter Module Data Guide
    http://www.linxtechnologies.com/Docu...Data_Guide.pdf
    LR Series RF Receiver Module Data Guide
  1. Generic RF Receiver
    By dhouston in forum Code Examples
    Last Post: - 8th September 2009, 15:35
  2. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 13:52
  3. Help with CC1100 RF Modules.
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 27th November 2006, 21:58
  4. RF designs
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 14th June 2006, 08:50
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 23:27
