ADCON1 settings 18F4620
Results 1 to 9 of 9
    Jan 2007
    Houston, TX
    ADCON0 controls operation of A/D module
    ADCON1 configs functions of port pins
    ADCON2 configs A/D clock source
    this is page 224 DS39626, page 226 in pdf view
    Padawan-78
    Jan 2007
    Houston, TX
    OK, here is what I do understand,
    for ADCON1 control register.....I need...
    bit 7 = 0
    bit 6 = 0
    bit 5 = 1 'I am using Vref- AN2
    bit 4 = 1 ' I am using Vref+ AN3
    what I still don't understand....from page 224
    bit 3 = ?
    bit 2 = ?
    bit 1 = ?
    bit 0 = ?
    Padawan-78
    Hangover, Germany
    Red face
    Some trick:
    If there are analog signals on inputs, they can drive the current through the inputs to an high level, if they are digital inputs !
    So,
    you can declare all the inputs as analog and switch them to digital in the case of reading a digital input and switch them back to analog after (ADCON1).
    You can switch all the AN3... to digital and see what happens ;-)
    You can read the analog value without problems!
    You can arrange the analog inputs on the first AN-channels !!!!!!
    Jan 2007
    Houston, TX
    Thumbs up Got err done
    Duh,
    Got It!
    I cannot pick and choose around which inputs I want I have to start with AN0 and work my way up or not at all.
    thanks for the blunt yet helpful comments!
    Just had to figure out how to read the table....had to look at the big picture.
    Padawan-78
    Quote Originally Posted by earltyso View Post
    Duh,
    Got It!
    Great! And believe it or not, that one little table and the way it is written and works, ties into soooo much other PIC stuff...so you didn't learn one thing...you learned a hundred things...just not all at once...YET...
    Problem is...now you'll be up until all hours of the morning trying to figure out what to do next with all that new knowledge...
  1. Confused over A/D settings
    Last Post: - 22nd February 2010, 11:44
  2. LM35DZ and 18F2455 settings
    By Mark J in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 09:31
  3. Config settings
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 12th December 2007, 19:24
  4. ADCIN - AD settings are wrong
    By teverett in forum mel PIC BASIC Pro
    Last Post: - 4th December 2006, 17:32
  5. Help with setting adcon1 for 16f877
    Last Post: - 16th August 2005, 12:13
