Setting / resetting a variable bit within a byte
Results 1 to 9 of 9
    Sep 2005
    Campbell, CA
    Default Setting / resetting a variable bit within a byte
    To clear bit 3 in Variable1, I find that
    If Y = 3 -
    The statement:
    Variable1.Y = 0 does not compile, while
    Variable1.0[Y] = 0
    DOES compile - but does it work properly? I don't have any
    hardware to test it on tonight. Even if it does work, is there
    a better way?
    Charles Linquist
    Oct 2007
    Vancouver, BC, Canada
    do it this way
    if y=3 then
    variable.3=0
    ________________
    KV
    Sep 2005
    Campbell, CA
    To do it your way, if I had a WORD variable, I would need 16 IF..THENs or 16 CASE statements. There has to be a better way.
    Charles Linquist
    Hi Charles. This .0[x] thing is old news but works very well. It's an undocumended feature.
    I do not think there is a more compact way than this. Why don't you like it?
    Sep 2005
    Campbell, CA
    It isn't that I don't like it. I just wasn't sure it would work. I thought I remembered the syntax, but when I searched for the technique on the forum for some reason it didn't come up.
    Thanks!
    Charles Linquist
    Quote Originally Posted by Charles Linquis View Post
    Thanks!
    I'm sure you've seen this thread by Melanie right?
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    A lifesaver thread for sure...
    Thanks!
    If you search the forum with the right tool it will reveal the secret!
    look at this:
    http://www.google.com/custom?q=%22.0...picbasic.co.uk
    And from now on you may use the:
    http://www.picbasic.co.uk/forum/showthread.php?t=4751
    to search the forum for sort terms like ".0["
    Last Post: - 14th June 2016, 07:55
  2. LCD freeze
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 5th October 2009, 08:01
  3. byte compression
    By Norbert in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 18:04
  5. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 11:47
