Setting / resetting a variable bit within a byte
Results 1 to 9 of 9
    Sep 2005
    Campbell, CA
    To do it your way, if I had a WORD variable, I would need 16 IF..THENs or 16 CASE statements. There has to be a better way.
    Charles Linquist
    Hi Charles. This .0[x] thing is old news but works very well. It's an undocumended feature.
    I do not think there is a more compact way than this. Why don't you like it?
    Sep 2005
    Campbell, CA
    It isn't that I don't like it. I just wasn't sure it would work. I thought I remembered the syntax, but when I searched for the technique on the forum for some reason it didn't come up.
    Thanks!
    Charles Linquist
    Quote Originally Posted by Charles Linquis View Post
    Thanks!
    I'm sure you've seen this thread by Melanie right?
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    A lifesaver thread for sure...
    Thanks!
    If you search the forum with the right tool it will reveal the secret!
    look at this:
    http://www.google.com/custom?q=%22.0...picbasic.co.uk
    And from now on you may use the:
    http://www.picbasic.co.uk/forum/showthread.php?t=4751
    to search the forum for sort terms like ".0["
    Sep 2005
    Campbell, CA
    I vaguely remembered seeing the solution awhile back, but forgot the details. I do something similar in my own "monitor" program in Code Examples, so I should have known better.
    Melanie doesn't seem to answer as many questions as she used to.
    Melanie, are you there? Is your lack of posts the result of being disgusted with us, or are you busy?
    Charles Linquist
    I vote for 2.
    Last Post: - 14th June 2016, 07:55
  2. LCD freeze
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 5th October 2009, 08:01
  3. byte compression
    By Norbert in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 18:04
  5. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 11:47
