Sim Card
Results 1 to 6 of 6
Thread: Sim Card
    Mar 2004
    Manila
    Default Sim Card
    Anyone knows how to read/write to Sim card using PIC?
    I don't know where to start. Pls... your assistance is highly appreciated.
    Brenda
    I believe they work exactly as normal memory cards. They respond to the ATR (Answer to Reset). Also their connection is the same as in the memory cards. So if you have managed to work with normal memory cards you will not have any difficulty. The only problem might be the connector. I used a plastic card from an older phone and stick the SIM with self adhesive tape.
    Attached you will find a program in PBP i used to read from an old Tele-Card to open a door lock. I realy do not remember the connection but it is easy to figure. If I find them I will schetch and send.
    Mar 2004
    Smart cards are just a micro and eeprom. A gold card is a 16f84A and an eeprom. To use the eeprom memory simply write a small routine to program into the 16f84A that allows commands to store and retrive data. Then on your pic that is using the smartcard for storage, program these commands accordingly.
    Mar 2004
    Manila
    Thanks for the reply.
    Yes, I have read sometime ago that a smart card has a pic in it. but i don't know really how it works.
    Ionis,
    I would be greatfull if you can provide me your schematic. I try to find out the difference of mobile sim card and the smart card.
    nice site mister_e
    best regards,
    brenda
    Mar 2004
    Hope this helps
  1. TTL magnetic card reader interface ith PC
    By attabros in forum Schematics
    Last Post: - 24th February 2016, 07:04
  2. PIC16 + sim cards
    By comwarrior in forum General
    Last Post: - 15th September 2009, 16:34
  3. gsm card reader using pic
    By ninebarmaximus in forum General
    Last Post: - 6th December 2005, 18:08
  4. Smart card reader with PIC16F84A
    By bangunprayogi in forum Serial
    Last Post: - 12th August 2005, 10:36
  5. Reading Magnetic Card on Pic16f876
    By Finn in forum mel PIC BASIC Pro
    Last Post: - 4th February 2004, 23:36
