PICBasic newbie problem
Results 1 to 33 of 33
    And: what : makes : your : coding : style : different : than : anyone : elses :....;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    I like to think of it in these terms:
    My code takes up less space on the screen...
    Most other's code takes up less space in the brain...
    I'm : having : a : stack : overflow :
    Me too :::::::::::::::::::)))))))))))))))))))))
    At any rate, just to prove I'm not an _ _ _ (insert word here)...here's some cut down 3 channel code I use on a 16F628A running at 20Mhz.
    Interrupt driven 8 bit, 76Hz software PWM for RGB.
    You got a timer (Timer 0) running as fast as it can, interrupting at 19,531.25 Hz. That increments a byte counter, pwmcount.
    You got 3 duty cycle registers (reddcr, greendcr, bluedcr). If the individual duty cycle register is less than the pwmcounter, the LED stays on, if not the LED goes out.
    Change the DCRs in the mainloop and it should work.
    Like I said, this is cut down code. The full code works just fine for me, but I took out all of the serial interface code, the 5 button interface code and the serial LCD code. Might work, might not. Pay attention to how the hardware hooks up (3 LEDs on PortA, that's it).
    The code should fade the 3 LEDs each in turn in about one second from off to full brightness, over and over again, 3 seconds for all 3 LEDs, wash lather rinse repeat.
    But if you can't make an LED blink in the first place, DO THAT BEFORE YOU TRY THIS!
    'PWM loop is @ 19,531.25 hz, w/ 256 cnt res, Freq of PWM is 76.2939hz
    @ DEVICE PIC16F628A , HS_OSC , WDT_OFF , PWRT_ON , MCLR_ON , BOD_ON , LVP_OFF , PROTECT_OFF	'HS 20mhz osc, watchdog off, powerup timer on, mclr external, brown out detect on, low volt program off , code protect off for now
    resetplaceholder:
    DEFINE		OSC		20	'20mhz
    DEFINE		NO_CLRWDT	1	'don't clear the watchdog timer, I'm not using it anyways
    DISABLE				'disable software interrupt checks
    CLEAR					'clear out the ram and do a software 'reset'
    redled var porta.0:greenled var porta.1:blueled var porta.2:chx var porta:reddcr var byte:greendcr var byte:bluedcr var byte:ledtemp var byte:pwmcount var byte
    temp var byte : temp2 var word
    startupholder:	goto skipsubs		'skip over all the commonly used subroutines
    ON INTERRUPT GOTO INTHANDLER
    DISABLE INTERRUPT
    INTHANDLER:	if intcon.2 = 1 then						'if tmr0 rolled over
    			intcon.2 = 0						'reset timer 0 overflow flag
    			if pwmcount = 0 then				'if pwmcounter has rolled over
    				if reddcr <> 0 then ledtemp.0 = 1	'turn off red leds if dcr is 0 (dcr = duty cycle register for LED), otherwise turn it on
    				if greendcr <> 0 then ledtemp.1 = 1	'turn off green leds if dcr is 0
    				if bluedcr <> 0 then ledtemp.2 = 1	'turn off blue leds if dcr is 0
    				chx = ledtemp		'update port pins of led status (on or off), can do this because all the LEDs are on the same port
    			if reddcr < pwmcount then ledtemp.0 = 0	'if the channel's dcr (duty cycle register) is less than the pwmcounter, turn that channel off, otherwise, leave it on ( < rather than <=, fixes problem with pulsing at high rates)
    			if greendcr < pwmcount then ledtemp.1 = 0
    			if bluedcr < pwmcount then ledtemp.2 = 0
    			chx = ledtemp : pwmcount = pwmcount + 1	'update the port pins and increment the pwmcount
    intfinish:	RESUME
    'commonly used subroutines start here
    alloff:		reddcr = 0 : greendcr = 0 : bluedcr = 0 : return	'turn off all leds thru dcr's
    allon:		reddcr = 255 : greendcr = 255 : bluedcr = 255 : return     'turn on all leds
    skipsubs: option_reg=8:pie1=$20:trisa=0:porta=0:trisb=$ef:portb=$10:t1con=0:t2con=0:cmcon=7:ccp1con=0:vrcon=0:pir1.5=0:ledtemp=0:redled=0:blueled=0
                   greenled = 0 : intcon = $e0
    ENABLE INTERRUPT
    mainloop:
    for temp=0 to 255:reddcr=temp:for temp2=0 to 2603:pauseus 1:next temp2:next temp:for temp=0 to 255:greendcr=temp:for temp2=0 to 2603:pauseus 1:next temp2
    next temp:for temp=0 to 255:bluedcr=temp:for temp2=0 to 2603:pauseus 1:next temp2:next temp:goto mainloop	'do it over again
    And for those that don't like colons...
    resetplaceholder:
    redled var porta.0
    blueled var porta.2
    chx var porta
    reddcr var byte
    greendcr var byte
    bluedcr var byte
    ledtemp var byte
    pwmcount var byte
    temp var byte
    temp2 var word
    startupholder:
    DISABLE INTERRUPT
    INTHANDLER:
    if reddcr <> 0 then
    ledtemp.0 = 0
    ledtemp.1 = 0
    ledtemp.2 = 0
    chx = ledtemp
    intfinish:
    RESUME
    alloff:
    reddcr = 0
    greendcr = 0
    bluedcr = 0
    allon:
    reddcr = 255
    greendcr = 255
    bluedcr = 255
    skipsubs:
    option_reg = 8
    pie1 = $20
    trisa = 0
    porta = 0
    trisb = $ef
    portb = $10
    t1con = 0
    t2con = 0
    cmcon = 7
    ccp1con = 0
    vrcon = 0
    pir1.5 = 0
    ledtemp = 0
    redled = 0
    blueled = 0
    greenled = 0
    intcon = $e0
    ENABLE INTERRUPT
    mainloop:
    for temp = 0 to 255
    reddcr = temp
    for temp2 = 0 to 2603
    pauseus 1
    next temp2
    next temp
    for temp = 0 to 255
    greendcr = temp
    pauseus 1
    next temp2
    next temp
    for temp = 0 to 255
    bluedcr = temp
    pauseus 1
    next temp2
    next temp
    goto mainloop	'do it all over again
    3 channels ...
    No, No, No!
    You said you could do 48 channels.
    That's what they want.
    Frankly, I'd like to see 48 chanels of 8-bit software PWM too.
    3 channels ...
    No, No, No!
    Frankly, I like to see 48 chanels of 8-bit software PWM too.
    Well, the basics are there (as you well know)...
    And the 48 channels...I'll post some differences:
    18F8722 vs. 16F628A
    40Mhz vs. 20Mhz
    Timer 0 prescale is 1:2 instead of 1:1, thereby keeping the same 76Hz Freq of PWM...
    ...got 512 cycles to work with instead of 256. 48 channels in 512 cycles = 10 cycles per channel with even some extra leftover.
    Code is practically the same, except:
    PWM 0-7 on PortB (along with PGC/PGD/PGM, LVP disabled)
    PWM 8-15 on PortD (serial comm's on PortC, along with a couple of buttons)
    PWM 16-23 on PortE
    PWM 24-31 on PortF
    PWM 32-39 on PortH
    PWM 40-47 on PortJ
    The rest of the pins are either used for buttons, indicators, or whatever, the usual crap.
    At first I had a heck of a time finding enough cycles to run everything thru the interrupt loop and not miss any interrupts, that's when I figured out to keep all of the PWM channels in blocks of 8, byte writes to each port instead of bit writes saved just enough time to make it work reliably and leave a bit of time leftover to actually have a MAINLOOP to do other things. There's a few other shortcuts in the interrupt loop, such as checking the high bit of each DCR instead of checking the whole thing when doing the comparisons. That's one of the places where the PWM jitters a bit (I never said it was a ROCK SOLID 48 channels!). If too many of the channels have to take the jump where it sets or resets the pin, the PWM for all of them hiccups a bit. Worst case scenario is when all DCRs for each channel are exactly the same, they all have to take the jump to reset the pins. But if they're spread out, it's not bad at all. I can even trace it on the 'scope and only get a couple of us of jitter.
    THERE! Now everybody knows all of my secrets!
    You know, come to think of it...this might be one of those things just would go good with that little 'code optimization' exercise that went on awhile back.
    Get an '8722 to use every available pin for software driven PWM'ing of LEDs, while using the serial port for control at high speed, and still have solid PWM.
    HMMMMMMMMM . . . . not an _ _ _ . . . what could that be . . ( Joe mutters to himself with a big grin on his ugly mug) E G G . . . no that's too obvious . . D O G . . . perhaps, no . . . HMMMMMM , what could it be? D O N K E Y? No too many letters . . . HMMMMMMM . . . What could it be . . . ? HE HE HE HE HE HE . . . .
    I'll even give you a hint there...
    Since I wrote 'not AN _ _ _' vs. 'not A _ _ _'
    then it can be assumed that the 3 letter word does in fact start with a vowel...
    I had come up with so many possibilities
    Especially after reading this ...
    <a href="http://www.dailywritingtips.com/using-a-and-an-before-words/">http://www.dailywritingtips.com/using-a-and-an-before-words/</a>
    hmmmmmmmm . . . not AN . . . EAR . . . OWL . . . OAR . . . ? Be very careful if you pick one because there's lots of 3 letter words you do not want to be Lucky for me you are <font color=red>not</font color> AN overly sensitive drama queen ! and allow me to pick on you a little . . . all in fun though!
    I found another hint
    The High Colonic Master...yep...that's me...
    and another
    So I used Google and came up with this
    http://en.wikipedia.org/wiki/Colon_(anatomy)
    These puzzles are fun, when can we do another?
    Sorry skimask, I could not help myself
  1. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  2. Picbasic Newbie Problem
    By Stargazer3141 in forum mel PIC BASIC
    Last Post: - 21st August 2007, 18:40
  3. Problem on writing EEPROM in Winpic800 with picbasic pro
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 17:33
  4. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 05:36
  5. DMX & PicBasic coding problem
    By magicmarty in forum mel PIC BASIC Pro
    Last Post: - 20th September 2004, 16:35
