the PIC only sends out 0-5 volts, but the PC needs to receive 0 - 10 volts... just like its sends 0 - 10 volts...
how can I send a signal of 0 - 10 Volts to the PC, when I use a PIC that only sends out 0-5 volts..
So.......
Are you trying to make a digital output (0 or 5v) from the PIC into an analog (0-10v) output to the PC? Why would a PC need to receive 0-10v? (I smell an RS232 question coming up in the next reply)
For what reason? A PC doesn't usually have an A/D converter on it...at least not one that the average joe can use with any success...unless you've got a PCI/ISA D/A card of some sort.
A lot of older theatrical dimming systems used 0-10V as a dimming reference. Is this what you want to do? You could use a DAC chip from MAXIM. How much current do you need to source?
Best Regards,
Kurt A. Kroh
KrohTech
“Goodbye and thanks for all the fish”
thanks you all, I'll manage it from here...
I was mistaken by saying I needed the 0 - 10 volts to send to pc, i am making an IO Board, that can be controlled by the PC, the analog output (0 - 10V) of the PIC will be used for controlling, what ever I want to make on that IO board...
Found info about a IO-Warrior24, that is quite similar to what I am making.
anyhow, I'll try the op-amp... that'll probably work
