0 - 10V input on PIC 16F876
Results 1 to 19 of 19
    Feb 2008
    thank you actually it seems quite obvious, why didn't I think of it, but thanks...
    but what if I want to use the 0 - 10 volts as an output...
    it only sends out 0 - 5 volts...
    is there some kind of transistor that when the base opens in the range of 0 - 5V, the transistor slowly opens, and sends out (from collector to emitter) a range of 0 - 10Volts... or is there another way??
    Angry Some have given their time ... but Whhhhhhyyyyy ???
    a little search on this forum could have raised Our Friend Darrel had designed a more than fair tool for such voltage dividers calculations.
    and overall some idiotproof items included ...
    Quote Originally Posted by slayerizer View Post
    What do you mean? Take as an input 0-5 and output 0-10Volts?
    Feb 2008
    the PIC only sends out 0-5 volts, but the PC needs to receive 0 - 10 volts... just like its sends 0 - 10 volts...
    how can I send a signal of 0 - 10 Volts to the PC, when I use a PIC that only sends out 0-5 volts..
    So.......
    Are you trying to make a digital output (0 or 5v) from the PIC into an analog (0-10v) output to the PC? Why would a PC need to receive 0-10v? (I smell an RS232 question coming up in the next reply)
    For what reason? A PC doesn't usually have an A/D converter on it...at least not one that the average joe can use with any success...unless you've got a PCI/ISA D/A card of some sort.
    Sep 2007
    Default 0 - 10 volt
    A lot of older theatrical dimming systems used 0-10V as a dimming reference. Is this what you want to do? You could use a DAC chip from MAXIM. How much current do you need to source?
    Best Regards,
    Kurt A. Kroh
    KrohTech
    “Goodbye and thanks for all the fish”
    That is an easy thing to do with an op-amp and a gain of x2. Use on like LMC66x series that are rail to rail capable.
    Now as skimask stated, why a PC would need 0-10Volts?
    Feb 2008
    thanks you all, I'll manage it from here...
    I was mistaken by saying I needed the 0 - 10 volts to send to pc, i am making an IO Board, that can be controlled by the PC, the analog output (0 - 10V) of the PIC will be used for controlling, what ever I want to make on that IO board...
    Found info about a IO-Warrior24, that is quite similar to what I am making.
    anyhow, I'll try the op-amp... that'll probably work
  1. Replies: 67
    Last Post: - 8th December 2009, 03:27
  2. input logic threshold level for pic 16F628
    By aratti in forum General
    Last Post: - 29th December 2008, 12:35
  3. Midi, Interrupts and Pic better than SX28?
    By Lajko in forum mel PIC BASIC Pro
    Last Post: - 27th September 2008, 01:26
  4. Can a PIC PIC a PIC?
    By afbecker in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 20:55
  5. Little pic trainer for 16F876
    By chkdsk in forum Schematics
    Last Post: - 8th August 2004, 18:21
