Serial Byte Format
Results 1 to 3 of 3
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Receiving data on the PIC with 2 stop bits will not be a problem because only one is required (and the others ignored as you suggested)
    Sending data from the pic, you will need to insert a 208 uS Pause after each byte you send to facilitate the second stop bit. (Alternatively, you can use 9 bit mode and make the 9th bit always equal to a stop bit)
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Dec 2007
    Smile Serial Byte Format
    Thanks Paul for the information, I just was not sure about the second stop bit, and the FT920 data information has a optcode to pace bits if I want and the suggest a 200 uSec pace between bytes of data sent out to the interface.. I think it should be able to handle that I will be using a 16f876 at 20mhz
    Thanks again ( this forum makes life easer!!!)
    Mike
  1. LCD freeze
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 5th October 2009, 09:01
  2. Memory use - how much do you use?
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 10th June 2009, 23:39
  3. byte compression
    By Norbert in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 19:04
  5. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 12:47
