Reading temperature using multi DS18B20
Results 1 to 17 of 17
    Sep 2011
    Default Re: Reading temperature using multi DS18B20
    Thanks! That clears that up. Do you know why the +1 on the end?
    The DIV32 command allows you to divide the 32 bit number held in internal registers. But that's not really important here. More importantly, why do we assign TEMPC, then reassign it again on the next line of code without using it.
    Apr 2011
    Thanks for posting your code. I was having difficulty with negative readings and converting to an integer. I saw what I was doing wrong, corrected my code and now I can read negative temperatures.
    thanks,
  1. Please help with code for DS18B20
    Last Post: - 28th April 2013, 22:12
  2. Multi DS18b20 Code help.
    By sccsltd in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 07:13
  3. DS18S20 reading negative temperature
    By srob in forum mel PIC BASIC Pro
    Last Post: - 28th December 2007, 22:21
  4. DS18B20 error reading
    By Gaetano in forum mel PIC BASIC Pro
    Last Post: - 29th August 2007, 17:21
  5. Reading 5 DS18B20 Problem
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 30th August 2005, 21:51
