Using serial eeprom to save data ?
Results 1 to 5 of 5
    Quote Originally Posted by iugmoh View Post
    11 bytes ( 88 bits)
    Added:
    Quote Originally Posted by skimask
    10,000 students @ 11 bits each = 88,000 bits.
    Dealing with 11 bits isn't worth the pain, so call it 16 bits, in other words, 2 bytes.
    Last edited by Darrel Taylor; - 6th February 2008 at 21:58. Reason: Added meaning of post
    Added:
    Well, I did say that I didn't even need a calculator....RIGHT? I could've SWORE that it said 11 bits...
    Nonetheless, the idea still remains...
    Except now the address pins on the 24LC256 might have to be used to put 4 of them on the same PCB.
    Or use I2CRead/Write with 2/3/4/5 different sets of pins to address the individual chips.
    Still not much of an issue is it?
    thanks alot for your information which help me very much , but I want to ask what about using usb stick flash disk I think it's a powerfull idea which it's easy to remove it and connect to PC to save data then connect to PIC to make interface for reading and writing in a quick manner, but how ?
  1. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 02:46
  2. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  3. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  4. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 19:42
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
