Can't get 18F2221 PLL to run with INTOSC
Results 1 to 15 of 15
    Thumbs up
    S-W-W-EET!
    Sep 2005
    Campbell, CA
    And one last "Gotcha" that I forgot to mention earlier - bits 0 and 1 of
    OSCCON *MUST* be set to "00".
    Even though you are running off the Internal Oscillator Block, if you
    enable the PLL, you have to configure for PRIMARY OSCILLATOR.
    Summary -
    To run off the Internal oscillator and use the 4X PLL:
    Set OSCCON bits 6 through 4 for either 8MHz (111) or 4MHz (110) and OSCCON
    bits 1 and 0 for PRIMARY OSCILLATOR (00)
    Set OSCTUNE.6 = 1 to enable the PLL.
    In that order!
    Charles Linquist
  1. Program compiles and writes but can't run
    Last Post: - 23rd March 2009, 05:38
  2. 18F4520 and internal osc & PLL
    By pwhitt in forum mel PIC BASIC Pro
    Last Post: - 15th September 2008, 07:38
  3. 16F628 and LMX2306 PLL loading.. help
    By kessral in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 18:03
  4. Pll?
    By atwoz in forum General
    Last Post: - 19th December 2007, 11:20
  5. Cannot compile for 40MHz 4 x pll
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 21st October 2007, 18:50
