AD works in Porta.0 but not in porta.1
Results 1 to 7 of 7
    Unhappy AD works in Porta.0 but not in porta.1
    Hi all,
    i've sucessfuly made some programs already but i'm still in a very rookie position.
    I'm working on a program ( pic 16F88 ) to read temp and save it into an external eeprom.
    Here's the code and at the end the questions
    SSPCON.5 = 0                ; Disable SSP Module
    TXSTA.5 = 0                 ; Disable AUSART Tx
    RCSTA.7 = 0                 ; Disable Serial Port
    OSCCON          = %01111110 'Internal RC w/ I/Os
    INTCON=0
    PIE1     = 0
    'PIE2    = 0
    PIR1                 = 0                   'off
    CMCON= 7
    CVRCON= 0                   'Vref Off
    CCP1CON= 0
    T1CON= 0
    'T2CON = %00000100
    'DEFINEs
    @ DEVICE INTRC_OSC
    @ DEVICE MCLR_OFF
    @ DEVICE PROTECT_OFF
    DEFINE osc 4
    @ DEVICE CPD_OFF
    @ DEVICE LVP_OFF
    @ DEVICE BOD_OFF
    @ DEVICE PWRT_OFF
    @ DEVICE WDT_OFF
    'ADC
    DEFINE ADC_BITS 10 ' Set number of bits in result ( 8 or 10 bits )
    DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
    'ADC parameters
    ADCON1  =%10000000      'right justify
    ANSEL   =%00000101
    ADCON0  =%11000001
    INCLUDE "modedefs.bas"
    'settings for serial comm
    DEFINE debug_reg PORTA
    DEFINE debug_bit 1
    DEFINE debug_baud 9600
    DEFINE debug_mode 1
    'I/O's
    PORTA=0
    PORTB=0
    TRISA=%00100101
    TRISB=%00000011
    'PINS
    temp    var PORTA.0
    out     var PORTA.1
    volt    var PORTA.2
    a3      var PORTA.3
    A4      var PORTA.4
    but1    var PORTA.5
    led2    var PORTA.6
    led1    var PORTA.7
    but2    var PORTB.0
    but3    var PORTB.1
    SCL     var PORTB.2
    SDA     var PORTB.3
    green    var PORTB.4
    red       var PORTB.5
    led4      var PORTB.6
    led3      var PORTB.7
    ' variables
    va       var word
    va2      var word
    tempe    var word
    volte    var word
    mem      var byte
    p1a      var word
    p1b      var word
    p2a      var word
    p2b      var word
    p3a      var word
    p3b      var word
    p4a      var word
    p4b      var word
    state   var byte
    st      var word
    ed      var word
    ADDR    var word
    m1      var  byte
    m2      var byte
    m3      var byte
    m4      var byte
    slot    var bit
    w       var byte
    CTW     VAR BYTE
    km      var byte
    ra      var word
    set1    VAR BYTE
    set2    VAR BYTE
    rm      var byte
    x       var byte
    CLEAR
    mem=1
    state=1
    p1a=$10
    p1b=$1070
    p2a=$1080
    p2b=$2140
    p3a=$2160
    p3b=$3220
    p4a=$3230
    p4b=$4290
    start:
    high out
    debug $0D, $0A
    PAUSE 50
    CTW=$A0
    debug "start menu",13,10
    startmenu:
    I2CREAD SDA,SCL,CTW,1,[m1]
    I2CREAD SDA,SCL,CTW,2,[m2]
    I2CREAD SDA,SCL,CTW,3,[m3]
    I2CREAD SDA,SCL,CTW,4,[m4]
    if (mem=1) and (m1=0) then
    led1=1
    led2=0
    led3=0
    led4=0
    slot=0
    if (mem=1) and (m1<>0) then
    pause 300
    toggle led1
    led2=0
    led3=0
    led4=0
    slot=1
    if (mem=2) and (m2=0) then
    led1=0
    led2=1
    led3=0
    led4=0
    slot=0
    if (mem=2) and (m2<>0) then
    led1=0
    pause 300
    toggle led2
    led3=0
    led4=0
    slot=1
    if (mem=3) and (m3=0) then
    led1=0
    led2=0
    led3=1
    led4=0
    slot=0
    if (mem=3) and (m3<>0) then
    led1=0
    pause 300
    led2=0
    toggle led3
    led4=0
    slot=1
    if (mem=4) and (m4=0) then
    led1=0
    led2=0
    led3=0
    led4=1
    slot=0
    if (mem=4) and (m4<>0) then
    led1=0
    pause 300
    led2=0
    led3=0
    toggle led4
    slot=1
    if state=1 then
    green=0
    red=1
    if state=2 then
    green=1
    red=0
    if state=3 then
    green=1
    red=1
    if (but1=1) and (state=1) then
    gosub readmenu
    if (but1=1) and (state=2) then
    gosub recordmenu
    if (but1=1) and (state=3) then
    gosub erasemenu
    if but3=1 then
    gosub memorymenu
    if but2=1 then
    gosub statemenu
    goto startmenu
    recordmenu:
    debug "Record Menu",13,10
    if slot=1 then
    goto warningmenu
    if mem=1 then
    st=p1a
    ed=p1b
    if mem=2 then
    st=p2a
    ed=p2b
    if mem=3 then
    st=p3a
    ed=p3b
    if mem=4 then
    st=p4a
    ed=p4b
    recordmem:
    debug "2s pause before start recording",13,10
    PAUSE 2000
            FOR ADDR= st TO ed
     	for w = 0 to 15
            ADCIN temp, va
            va2=va + (temp>>4)
            NEXT
    va = (va2 */ 5000 ) >> 2
    va=va/10
            toggle red
            pause  824
            debug " Saved value:  ", dec va2," - ", dec va," In position  ", dec ADDR, 13,10
            debug " VA2 = ", dec va2,13,10
            I2CWRITE SDA,SCL,CTW,ADDR,[VA.highbyte]
            pause 10
            ADDR=ADDR+1
            I2CWRITE SDA,SCL,CTW,ADDR,[VA.lowbyte]
            pause 10
            ADDR=ADDR+1
            I2CWRITE SDA,SCL,CTW,mem,[addr]
            if but1=1 then      'stop recording
            pause 600
            goto startmenu
            toggle led1
            toggle led4
            NEXT
            red=1
    erasemenu:
    eraseblock:
    debug "erasing block",dec mem,13,10
    red=0
    I2Cread SDA,SCL,CTW,mem,[x]
    debug "before in position ",dec mem," - ",dec x,13,10
    I2CWRITE SDA,SCL,CTW,mem,[0]
    red=1
    memorymenu:
    if mem < 4 then
    mem=mem+1
    mem=1
    debug DEC mem,13,10
    pause 300
    statemenu:
    if state < 3 then
    state=state+1
    state=1
    debug "state change - ", DEC state,13,10
    pause 300
    The code is mostly working but i have encountered some issues.
    One of them is the eeprom ( 24LC512 ). I cant access ( read or write ) into it.
    I have sucessfuly worked with this eeprom with a PIC12F675 but not with this 16F88
    Other issue is reading the temp sensor. If i connect the sensor into PORTa.1 i get no decent readings ( just 1 and 0 ).
    But if i change ADCON0, Ansel and Trisa to porta.0 it works.
    I'm guessing this is due to some bad configuration i dont know were.
    This is why i'm asking you pros to help me and take some questions away.
    questions:
    1.How do i turn the comparator off ?
    I'm guessing that CCP1CON will turn it off.
    If this is right, do i still need to add CMCON ?
    2. I'm using the internal osc ( with MCLR off ). The OSCCON option should be "10 = Internal RC is used for system clock".
    what does the other mean ?
    00 = Oscillator mode defined by FOSC<2:0>
    01 = T1OSC is used for system clock
    3. For AD i have seen 2 diferent ways of programing:
    One where we use a line to start the conversion, a line to capture the value and another to stop the conversion.
    I always used the ADCin portx,a mode to do the job.
    So, for ADCON0, my way i shoud use :
    "bit 0 ADON: A/D On bit - 1 = A/D converter module is operating"
    and "bit 2 GO/DONE: A/D Conversion Status bit - 1 = A/D conversion in progress (setting this bit starts the A/D conversion)"
    Am i right ?
    For the next bits :
    000 = Channel 0 (RA0/AN0)
    001 = Channel 1 (RA1/AN1)
    010 = Channel 2 (RA2/AN2)
    011 = Channel 3 (RA3/AN3)
    100 = Channel 4 (RA4/AN4)
    101 = Channel 5 (RB6/AN5)
    110 = Channel 6 (RB7/AN6)
    this means i can only choose one channel for ADC ? What if i need 2 input channels ?
    Finally the last bits:
    Since i'm using the internal OSC which one should i use and why ?
    bit 7-6 ADCS<1:0>: A/D Conversion Clock Select bits
    If ADSC2 = 0:
    00 = FOSC/2
    01 = FOSC/8
    10 = FOSC/32
    11 = FRC (clock derived from the internal A/D module RC oscillator)
    If ADSC2 = 1:
    00 = FOSC/4
    01 = FOSC/16
    10 = FOSC/64
    Sorry for the long post and many questions
    ruijc , You need to set ANSEL to enable the other input to be used by the A/D convertor....
    Thanks Dave
    I did that
    ANSEL   =%00000101
    So this means that this line is all i need to set which and how many Analog channels to be used ?
    This makes me confused because of the ADCON0 settings:
    So what does these ADCON0 settings mean ?
    ruijc, You really need to read the data sheet for the part. Yes, you are right about the adcon0 register as the value you write to it will select which a/d channel will be selected, however the ansel register selects the hardware connections to the a/d multiplexer. It only needs to be written 1 time unless you are changing the port directions.
    How about not working with PORTA.1 but working with PORTA.0 ?
    For PORTA.1 this is what i used diferent:
    ANSEL    =%00000110
    ADCON0  =%11001001
    TRISA     =%00100110
    This way it should work, right ? But it doesnt
    And how about the external eeprom ?
    I have connected this eeprom the same way as i connected to a pic12F675 but for the pic16F88 is not working.
    Do i need to do something diferent ?
    I've done some searches and some recomend to use the IC slow line, but this eeprom is high speed one and does not require that line.
    Any ideas ?
    ruijc, Here, Try this as it is known working code....
    @ __CONFIG _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_ON & _MCLR_OFF & _PWRTE_ON & _WDT_OFF & _HS_OSC
    @ __CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF
    DEFINE OSC 20
    DEFINE NO_CLRWDT 1
    ' Declare Port Variables
    ANA0 VAR PORTA.0 '1-1st PRESSURE SENSOR INPUT (MAIN SENSOR)
    ANA1 VAR PORTA.1 '1-2nd PRESSURE SENSOR INPUT (SPARE SENSOR INPUT)
    ' Declare Variables
    ADREADS VAR WORD 'A/D READINGS (0-4095)
    CHANNEL VAR BYTE 'A/D CHANNEL TO ACCESS
    SCRATCH VAR BYTE 'SCRATCH VARIABLE
    ' SYSTEM INITIALIZATION
    TRISA = %10100011 'INITIALIZE PORT DIRECTIONS
    TRISB = %00000000
    OSCCON = 0 'SET SYSTEM CLOCK SWITCH BIT
    INTCON = %00000000 'CLEAR GIE,PEIE,TMR0IE,INTE,RBIE,TMR0IF,INTF,RBIF
    PIE1 = %00000000 'CLEAR ALL INTERRUPT ENABLE BITS
    PIR1 = %00000000 'CLEAR ALL INTERRUPT FLAGS
    PIE2 = %00000000 'CLEAR ALL INTERRUPT ENABLE BITS
    PIR2 = %00000000 'CLEAR ALL INTERRUPT FLAGS
    ANSEL = %00000011 'AN0,AN1 ANALOG INPUTS, AN2:AN6 DIGITAL
    ADCON0 = %10000001 'FOSC/64,CHS2:0,GO/DONE,ADON
    ADCON1 = %11000000 'RIGHT JUSTIFIED,ADSC2,VCFG
    CMCON = %00000111 'CLEAR/DISABLE COMPARATOR
    CVRCON = %00000000 'DISABLE COMPARATOR VOLTAGE REFERENCE
    OPTION_REG = %10000000 'CLEAR ALL PULL-UPS,INTEDG,T0CS,T0SE,PSA,PS
    T1CON = %00000000 'PRESCALER 1/1,STOP TIMER 1
    T2CON = %00000000 'POSTSCALER 1/1,STOP,PRESCALER 1/1
    CCP1CON = %00000000 'PLACE CCP1 INTO DISABLE MODE
    TMR2 = 0 'CLEAR TMR2 MODULE REGISTER
    PR2 = $FF 'SET PERIOD (1/1 PRESCALE * 256 PR2 * 1/20,000,000 * 4 = 19.53 Khz.
    CCPR1L = $00 'CLEAR LOWER 8 BITS
    CCPR1H = $00 'CLEAR UPPER 2 BITS
    SSPCON = %00000000 'PLACE SSP INTO DISABLE MODE
    SPBRG = 0 'SET LOW BYTE OF BAUD GENERATOR
    RCSTA = %00000000 'DISABLE RECEIVER,CONTINUOUS
    TXSTA = %00000000 'DISABLE TRANSMIT,HIGH BAUD
    ' INTERBIT = INTCON.7 'SAVE STATUS OF INTERRUPT ENABLE BIT
    ' INTCON.7 = 0 'DISABLE ALL INTERRUPTS
    ' INTCON.7 = INTERBIT 'RE-ENABLE ALL INTERRUPTS
    GOTO COLD
    '************************************************* *******************' Subroutines
    '************************************************* *******************READAD: 'READ ALL A/D INPUT CHANNELS FROM CONTROLLER
    CHANNEL = 0
    WHILE CHANNEL < 2
    ADCON0 = $81 | (CHANNEL << 3) ' Set A/D to Fosc/64, Channel X, On
    PAUSEUS 40
    ADCON0.2 = 1 ' START CONVERSION
    NDONE:
    while ADCON0.2 = 1 ' WAIT FOR 10 BIT CONVERSION TO COMPLETE
    wend
    volts(channel) = (((ADRESH & $3) << 8) + ADRESL) 'BUILD SENSOR WORD
    CHANNEL = CHANNEL + 1
    WEND
    Cold:
    Dave Purola
  1. PORTA.0 works, PORTB.7 or .6 do not
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2009, 05:25
  2. Replies: 11
    Last Post: - 12th July 2008, 03:36
  3. Serout problem
    Last Post: - 25th February 2007, 14:33
  4. Someone help me to simplify this
    By thrix in forum General
    Last Post: - 21st February 2004, 06:01
  5. Help wanted..
    By thrix in forum mel PIC BASIC Pro
    Last Post: - 18th February 2004, 00:44
