SIMPLE question
Results 1 to 8 of 8
Thread: SIMPLE question
    Feb 2005
    GREECE
    Default SIMPLE question
    I am happy to be a member of that forum!!!!
    I have a SIMPLE question.
    I need to look at the 10 pins (portb.0-portb.7,porta.0,porta.1) in a loop and find the first pin that set 1.I need the simplest code to check that ports.
    Nikos
    North Norfolk UK
    Hi Nikos
    I too am happy to be a member of this forum!!!
    You could alias each pin into a word variable.
    Then simply check the value of the whole word
    If w0 > 1 then
    etc etc
    or
    while w0 <> 0
    wend
    I guess there are lots of other ways but this came into my mind first.
    Hope this Helps
    Duncan
    Feb 2005
    GREECE
    Good idea Duncan,
    But I want to find exactly the pin that is 1.
    When you say word(variable)that can have 10bits???
    Nikos
    North Norfolk UK
    Hi Nikos
    A word is indeed 16bits, there is a great post by Melanie in the FAQ section I think, which describes how to address bits bytes words and arrays,
    but I think first it is worth taking the time to fully digest pages 21 to 24 of the PBP manual. Every minute taken will pay back in Spades. Settle back with a nice cool glass of retsina.... take your time.
    Just in case you do search for other info: a nybble is 4 bits but PBP does not access these directly.
    Cheers and good luck
    Duncan
    North Norfolk UK
    Hi again,
    I did not answer your question fully,
    you can determine which bit in the word variable that has been set by its value.
    if w0 = 8 this is the same as %0000000000001000
    so if you aliased say portb.1 to bit <3> in the word then you would know that when w0 = 8 portb.1 = 1
    etc etc
    Duncan
    Its many years since i had a glass of retsina.. but you know I can still smell it even now
    Hi, N'Geron
    you can use:
    For I = 0 to 7
    IF PORTA.0[I] = 1 THEN Bail_out
    NEXT I
    For I = 0 to 1
    IF PORTB.0[I] = 1 THEN Bail_out
    NEXT I
    In simple words, you add the value I to the "Base address" that is PORTA.0 ... same for PortB
    You have it "officially written" in the 2.50 Manual, at th REPEAT --- UNTIL Command page !!!
    Feb 2005
    GREECE
    Duncan,
    What I was thinking...
    portA PORTB
    % 00000000 / 00001000
    <0> PORTB.0 <1>PORTB.1 .... <8>PORTA.0
    Let's say that this is my word that Contains PORTA+PORTB that I have to check.
    The followings are correct???
    w0 var word
    L var byte
    H var byte
    L = PORTB
    H = PORTA
    w0.LowByte = L
    w0.HighByte = H
    If w0 > 1 then
    I WILL READ THE w0
    Nikos
    Retsina,Summer,Sea and Sun
    Feb 2003
    Salt Lake City, Utah USA
    Quote Originally Posted by ngeronikolos View Post
    Duncan,
    portA PORTB
    (w0 var word
    L var byte
    H var byte
    L = PORTB
    H = PORTA
    w0.LowByte = L
    w0.HighByte = H
    If w0 > 1 then
    I WILL READ THE w0
    Nikos
    If that is what you want to do, you could use Darrel's trick with EXT
    @PORTS = PORTA
    PORTS VAR WORD EXT  ; PORTS = PORTB:PORTA
    ; in middle of program
    if PORTS > 1 then ....
    (Don' t forget to mask the unused bits of PORTA if they might not be 0)
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. Stupid simple question.....
    By chien_fu in forum mel PIC BASIC
    Last Post: - 23rd February 2010, 14:21
  2. Simple Timer question
    By jimseng in forum mel PIC BASIC Pro
    Last Post: - 25th September 2009, 00:12
  3. Really simple question for you experts :)
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 4th June 2008, 02:43
  4. really simple, dumb question
    By picster in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2007, 23:02
  5. really simple adcin question
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 21st April 2006, 10:06
