Highest Baud
Results 1 to 8 of 8
Thread: Highest Baud
    Santana's Avatar
    Santana Guest
    Default Highest Baud
    Hello people
    Does anyone know the highest Baud rate i can get with a
    20mhz Xtal and 18F452 ?
    the highest i can get using windows xp is 115200
    i am using Max232
    ' Setup Hardware for uart
    DEFINE HSER_BAUD 115200
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_CLROERR 1
    Synchronous... Datasheet... Table 16-3... 5Mb...
    Asynchronous... Datasheet... Table 16-4... 312.5kb...
    Santana's Avatar
    Santana Guest
    So thats clear would the problem be from my pc end then?
    20Mhz isn't the greatest xtal frequency to produce high baud rates compatible with your PC without error... see item 3 from my reply on this thread...
    http://www.picbasic.co.uk/forum/show...=&threadid=563
    I always use DEFINE HSER_SPBRG instead of DEFINE HSER_BAUD. In some case, it appear to be more efficient
    be sure of your DEFINE HSER_RCSTA and DEFINE HSER_TXSTA setting too.
    regards
    Santana's Avatar
    Santana Guest
    Thanks Mel
    i have taken your advice on board and i have ordered a 22mhz
    xtal.
    but i think my problem is with my PC End
    When i select any baud rate greater than 115200. i get a reply
    from hyperthem that com1 not found
    It is possible that Hyperterminal interrogates your PC's USART... I have XP-Pro SP2 on two four-month old 3.2Ghz desktop machines and a year old 2GHz Laptop... neither desktop lets me set a value higher than 115kb (the highest displayed), yet on the laptop, it permits setting right up to 920kb.
    Italy
    Hi!
    Some useful links...
    Luciano
    Terminal program:
    (No setup, only one EXE file).
    Terminal v1.9b 20040714.
    http://bray.velenje.cx/avr/terminal/
    (See custom baudrate).
    Does your PC need a high-speed serial port?
    Take a look at:
    http://www.comtrol.com
    (RocketPort Plus PCI 2-port 98701-7)
    RocketPort® Multiport Serial Controller Cards
    The RocketPort's fully integrated, ASIC controller has superior throughput performance, reliability, and CPU utilization, making this price/performance leader ideal for data acquisition applications. Highlights include:
    Optimum throughput performance up to 921 Kbps transmit and receive across all ports simultaneously.
    Supports PCI 32- and 64-bit, 3.3 Volt, 5.0 Volt, PCI-X, CompactPCI slots and ISA bus architectures, ensuring compatibility regardless of the host environment.
    Quick, easy installation using no interrupts or memory-mapping, freeing limited resources to support other hardware components/peripherals.
  1. A Serial GLCD 128x64 Simple Project
    By Oldspring in forum Off Topic
    Last Post: - 8th March 2010, 21:58
  2. PIC 18f1220 EUSART Baud Rate Cache Problem
    By wklose99 in forum Off Topic
    Last Post: - 15th April 2008, 01:39
  3. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 03:17
  4. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 23:41
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 17:48
