ws812 matrix rotate
Results 1 to 7 of 7
    Default ws812 matrix rotate
    just playing with a ws812 8x8 array and looking for a nice way to rotate a 8x3x8 byte array through 90 degrees, I have left and right shift and up/down sorted but a tidy rotate cw and ccw method is eluding me . any thoughts
    the code here is a work in progress and not very well commented
    Default Re: ws812 matrix rotate
    I'm thinking complete new array, an inplace rotate give me brain fade
    for row = 0 to 7
    for column = 0 to 7
    for element = 0 to 2
    new_pixel[column*(7-row)+row*(7-column)+element]= pixel[row*8+column*3+element ]
    next
    next
    next
    the penny dropped its a 24 byte wide row , had 8x8 burnt into brain
    for row = 0 to 7
    for column = 0 to 7
    new_pixel[3*(7-row)+24*column+element]= pixel[row*24+column*3+element ]
    next
    next
    next
    its so easy when you know how
    to go ccw
    for row = 0 to 7
    for column = 0 to 7
    new_pixel[3*(row)+24*(7-column)+element]= pixel[row*24+column*3+element ]
    next
    next
    next
    Aug 2003
    Hi Richard, did you mean rotating 2D 90 degrees each time you call the function?
    If so I wish I’d looked a this. It's in my display code, Tetris has to do it I used a lookup table for block rotation,
    but rotated digits for vertical orientation.
    its a 2d 8x8 matrix each element is 24 bits (rgb) the lot rotate 90 deg with each call . the cw and ccw both work flawlessly and are fairly quick too .
    a 45 deg rotate would be interesting.
  1. rotate bytes in array
    By Art in forum mel PIC BASIC Pro
    Last Post: - 15th March 2012, 23:59
  2. 2D Matrix Rotation
    Last Post: - 16th February 2010, 13:34
  3. Help led matrix
    By mosbc69 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:54
  4. Dipswitch matrix
    By DynamoBen in forum Off Topic
    Last Post: - 8th October 2007, 18:11
  5. need help with switch matrix
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2005, 19:59
