PIC12F629 or 8pin
Results 1 to 24 of 24
    Dec 2003
    Wichita KS
    Hello Andy,
    andy>>Ok, to recap and hopefully stop pestering you guys this is what I assume is correct:<<
    Hey, keep on pestering us...This is what fun is all about. learning, helping, communicating, and enjoying.
    Yes, you are correct. Now, if you want to control a bunch of chips, the same principal applies... for example
    Transmitter chip:
    Gosub Loop:
    goto Main
    Loop:
    SEROUT pinx,2400,"Chip3","Y"
    if (pinRx <>1 goto Loop 'this is the pin to confirm received.
    Serout Pinx,2400,"Hello World! this is Chip3"
    Loop2:
    Serout Pinx2400, Chip5,"Y"
    If pinRx<>1 goto Loop2 'this is the pin to confirm received
    Serout Pinx2400, "Howdy! my chip 5 is working\"
    Your receiver 3 is as follows:
    Loop1:
    Serin Pinx,2400,Chip3,Var
    If Var <>"Y" then Loop1
    PinRx=1 'send a high to the transmitter to tell it to send data fAST!
    while val<>"\"
    Serin Pinx,2400,val
    LCDout Val
    Wend
    PinRx=0 ' don't keep that pin on! other receivers may need it
    Your other receivers are exactly the same...Just change teh second line down from
    to
    Serin Pinx,2400,Chip5,Var (for receiver 5)
    Granted I did all of this in Psuedo code. But if you put the correct punctuation in it, it should come close to running. like putting the "N" before the 2400 to make it N2400, or whatever you like.
    I am uploading a picture for you....don't mind my professional drawing...The chips are how mine look after a weeks worth of use <g>.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
  1. semaphore pic12f629
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 7th November 2008, 13:55
  2. pic12f629 EEPROM problem in MPLABSIM
    By nicholastyc in forum General
    Last Post: - 16th May 2008, 18:10
  3. Ultrasound with PIC12F629
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 28th February 2007, 16:22
  4. Serial Input, PIC12f629
    By kdh0009 in forum mel PIC BASIC Pro
    Last Post: - 9th August 2006, 10:40
  5. PIC12F629, useing all I/O pins
    By Jcee324 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2004, 11:05
