Ok, to recap and hopefully stop pestering you guys this is what I assume is correct:
Loop:
SERIN portx,N2400,[“Chip1”],Var,
Monitor the serial port "X - TBA" until we see chip1, if found transfere the
following character into the var.
if Var= "A" Gosub turnonroutine_A
If the character after "Chip1" is "A" then goto the subroutine for A
if Var= "B" Gosub turnonroutine_B
If the character after "Chip1" is "B" then goto the subroutine for B
Var="0"
clear the var so it cannot have any further effect
goto Loop
turnonroutine_A:
Var="0"
Port1=1 'turn on
pause 500 ' 1/2 second pause
Port1=0 'turn off
turnonroutine_B:
Var="0"
Port2=1 'turn on
Port2=0 'turn off
One more thing confuses me with this:
Will Var always only be one character in length?
So if my string sent was say chip1AZ would var just have the A and ignore the Z
