Hserin and Timer0
Results 1 to 13 of 13
    Default Hserin and Timer0
    I have a question,I use Timer0 to Refresh my Real Time all is ok all work fine but my problem is when I use this:
    On Interrupt goto IntHandler ''''''''''''''''''''''''''''''''''''''''''''''''In terrupt Routine
    LoopHauptMenu:
    HSerin 10000,Main_RFID,[Menupunkt]
    Disable
    IntHandler:
    IF TMR0IF then Timer
    Resume
    Timer:
    TMR0IF = 0 '''''''''''''''''''''''''''''''''''''''''''''Clear Timer 0 Interrupt
    TMR0H = $3C
    TMR0L = $AF
    Gosub ReadTime
    Gosub Read_BCD
    Lcdout $fe,$80," RFID Leser "
    Lcdout $fe,$C0," ",DEC2 Stunde[0],":",DEC2 Minute[0],":",DEC2 Sekunde[0]," "
    Resume
    Enable
    Every 10 Seconds my Time is Refreshing!
    And when I use this :
    LoopHauptMenu:
    HSerin 1000,LoopHauptMenu,[Menupunkt]
    Disable
    IntHandler:
    Resume
    Timer:
    TMR0H = $3C
    TMR0L = $AF
    Gosub ReadTime
    Gosub Read_BCD
    Resume
    All is ok is refreshing every seconds why is this so?!
    Thank you for any answer.
    Regards Pesti
    Ok
    I found on the PBP book the Answer ,but not the solution.
    Where Can I found a good Assembler Interrupt example ?
    regards Pesti
    North Norfolk UK
    you could take a look at Darrel Taylors instant interrupts routines, http://darreltaylor.com/DT_INTS-18/home.html
    if you are using 18F's
    They have made interrupts so much easier, especially for me.
    HTH
    Duncan
    Hi
    I have try Darrels Instant Interrups ,but all the time show the Error 108.
    Warning[207] C:\PICHEX\USBWIZ.ASM 1849 : Found label after column 1. (warning)
    Error[108] C:\PICHEX\USBWIZ.ASM 1849 : Illegal character (")
    I can not found the Errors!
    Rgards Pesti
    Quote Originally Posted by Pesticida View Post
    Hi
    Rgards Pesti
    Do you have an extra ' <- yes, that character right there, the little extra tick
    in between a couple of quotation marks. They hide very well. Or maybe an extra quote mark somewhere?
    Hi Pesti,
    I get errors like those if I have spaces where they do not belong, I am sure you are using MPASM 'cause I think you have to for 18F parts, but Darrel's Instant Interrupts also require them. One more thing is Darrel has different DT_Instant interrupts for 16f and 18F series.
    JS
  1. HSERIN2 not working on PIC18F97J60 ???
    By mikebar in forum Serial
    Last Post: - 4th May 2008, 16:20
