VFD pinout and connections
Results 1 to 9 of 9
    Quote Originally Posted by rshaver View Post
    Thank you. I have the pinout can you or someone tell me the lcd equilavant for the following. Busy, Write Strobe, and Reset.
    Thanks again
    Ron
    Normal parallel LCDs (44780 compatible types, the types that are compatible with PBP) don't normally have a BUSY or a RESET pin.
    Sounds like it's time for you to write your own routines....either that or send them back.
    rshaver, I have used Noritake Itron 128x64 VFD graphical modules in the past. They have a RESET input as well as a BUSY output. I just reset the module before initialization and watch the busy line for the module to complete the command when entered. I have written my own character lookup table and output routine for these displays. Because of the timing and watching the busy output for the display to complete the command I have written my own output routines as well. I could not use LCDOUT, although I tryed........
    Jun 2007
    Thanks all. I did get it to display garbage but that is all. I guess I will set them on the shelf for later use. They were not that much so it is no problem. I'll get some that will replace the lcd's. I am going to use them in my truck and am kind of in a time crunch. Thanks again for all the feedback.
    Ron
    Jun 2006
    Default Noritake Itron 128x64 VFD interfacing
    Dear All,
    I have Noritake Itron 128x64 VFD (GU128*64D-K610A8) display.I want to use it is Async serial mode.I am struggling to display something on it.I am trying to send data using Hserout with defaults(19200baud,no parity etc).All that i get is random chars.
    Any code help would be appreciated.
    Quote Originally Posted by hell_pk View Post
    It is most likely a baud setting issue. What chip are you using, and what speed? This tool helps, if you are not using it already: http://www.picbasic.co.uk/forum/cont....-PICMultiCalc
    http://www.scalerobotics.com
    Jun 2006
    You were right,settings were incorrect.Its working now.
  1. Pinout for Orion P20005C LCD
    By rhino in forum Off Topic
    Last Post: - 26th April 2014, 10:16
