For...Next loop Steps DEC questions
Results 1 to 8 of 8
    Try this:
    Y var word
    Value var byte
    FOR Value = 0 to 255
        Y = ( Value * 51 ) / 26   'divided down from * 255 / 130
        LCDOUT 254,row1+1,"BATTERY:",DEC1 ( Y / 100 ),".",DEC2 ( Y // 100 )," VDC"
    Next Value
    Jan 2007
    Houston, TX
    Talking perfect
    SkiMask,
    Working great now....I realized that I had
    Y VAR BYTE instead of Y VAR WORD which caused my math to be all funky...
    I have also never used the // modulus math command either, I think I understand how that works now, I will play with 4 sig figs now to see If I get the rest all worked out.
    thanks a million!
    Padawan-78
    Quote Originally Posted by earltyso View Post
    SkiMask,
    thanks a million!
    If you've got PBP 2.50, you can use LONGs and get quite a bit of resolution...of course that'll be limited to your ADC also. 4 sig figs are easily doable with a 10-bit ADC...which obviously the PICs usually have.
  1. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 17:48
  2. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  3. PBPL 2.50 observations
    Last Post: - 18th September 2007, 00:58
  4. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 18:42
  5. Newbie question:
    By Izone in forum mel PIC BASIC
    Last Post: - 26th February 2006, 17:24
