For...Next loop Steps DEC questions
Results 1 to 8 of 8
    Quote Originally Posted by earltyso View Post
    Anyone,
    Can you create a decimal step for the FOR....NEXT LOOP?
    How about a Variable step?
    Ex:
    D VAR BYTE
    D = VALUE/10
    FOR value = 0 to 12 STEP + D
    or....
    For value = 0 to 12 step + .1
    I realize I am dealing with decimal values....can I use DEC3 command or somthing else to make this work?
    thanks
    Variable step . . .
    myVar Var byte ' up to 255 counts stored here
    If PortA.0 = 1 then myVar=12
    FOR value = 0 to myVar STEP + D
    or something to that effect . . .
    Jan 2007
    Houston, TX
    Unhappy another try
    I thought I had better restate what I am trying to do.
    I want to simulate an 8 bit input from A2D (referenced to Vpp +5V)
    using a FOR....NEXT loop. I want to see 0.00 climb up to 5.00 VDC...... on my LCD
    Can someone tell me why my code below does not work?
    Y var word
    Value var byte
    FOR Value = 0 to 0 STEP 255
    Y =(Value/255)*5 '8 bit resolution math
    LCDOUT 254,row1+1,"BATTERY ",DEC Y,".",DEC2 Y, " VDC" 'decimal point 3 sig figs
    pause 10
    next Value
    All I get on my screen is "BATTERY 0.00 VDC" and no change
    thanks...
    Padawan-78
    Sep 2007
    USA, CA
    your For value = 0 to 0 will only go through once.
    Jan 2007
    Houston, TX
    another try
    OK, so i screwed up my copy and paste, code still not working....
    any ideas??
    Y var word
    Value var byte
    FOR Value = 0 to 255
    pause 10
    next Value
    thanks...
    Padawan-78
    Try this:
    Y var word
    Value var byte
        Y = ( Value * 51 ) / 26   'divided down from * 255 / 130
        LCDOUT 254,row1+1,"BATTERY:",DEC1 ( Y / 100 ),".",DEC2 ( Y // 100 )," VDC"
    Next Value
    Jan 2007
    Houston, TX
    Talking perfect
    SkiMask,
    Working great now....I realized that I had
    Y VAR BYTE instead of Y VAR WORD which caused my math to be all funky...
    I have also never used the // modulus math command either, I think I understand how that works now, I will play with 4 sig figs now to see If I get the rest all worked out.
    thanks a million!
    Padawan-78
    SkiMask,
    thanks a million!
    If you've got PBP 2.50, you can use LONGs and get quite a bit of resolution...of course that'll be limited to your ADC also. 4 sig figs are easily doable with a 10-bit ADC...which obviously the PICs usually have.
  1. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 16:48
  2. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 05:02
  3. PBPL 2.50 observations
    Last Post: - 17th September 2007, 23:58
  4. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 17:42
  5. Newbie question:
    By Izone in forum mel PIC BASIC
    Last Post: - 26th February 2006, 16:24
