Outputs high to power
Results 1 to 3 of 3
    Default Outputs high to power
    Hi!
    I have a boards with a pic16f628a how can we ensure that the outputs go high for some fraction of a second when the power circuit?
    example configuration:
    @ device pic16f628A,xt_osc,wdt_on,pwrt_on,protect_off,mclr_ on,bod_Off
    define osc 4
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 9600 '
    DEFINE HSER_CLROERR 1
    SYMBOL s2 =PORTA.0
    SYMBOL s1 =PORTA.1
    SYMBOL canc_2 =PORTA.2
    SYMBOL stop_1 =PORTA.3
    SYMBOL power =PORTA.4
    SYMBOL ferma =PORTB.0
    ' =PORTB.1 'RX
    ' =PORTB.2 'TX
    SYMBOL led =PORTB.3
    SYMBOL canc_1 =PORTB.4
    SYMBOL canale2 =PORTB.5
    SYMBOL canale1 =PORTB.6
    SYMBOL stop_2 =PORTB.7
    cmcon=7
    OPTION_REG.7=1
    low canc_1
    low stop_1
    low canc_2
    low stop_2
    low led
    input s1
    input s2
    input canale1
    input canale2
    input ferma
    output canc_2
    output stop_1
    output power
    output led
    output canc_1
    output stop_2
    I can resolve this problem?
    Apr 2006
    Alberta Canada
    Put an LED on your output and to ground, if it lights up, then its High!!
    Post
    Hi, Volcane
    There are two things to consider :
    1) at power up ... Pic acts just like if you had forgotten to place it !!! ( all ports are INPUTS )
    ... so, you must design your power section according to that.
    2) you can program the outputs to be High, as soon as processor execute the TRIS command ( after some µsecs, then ....) :
    Write :
    PORTa = %11110101 ' for example
    TRISA = % 00001010 ' "
    Here you FIRST set the output latches in the correct state
    THEN choose your I/Os.
    This is THE classical "bug" for electronic ignitions ... coil is powered at poweron ... then the port is set to de-energize the coil ... results a nice "bang" or crankshaft back kick !!!
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. 12F629 Strange interupt behavior
    By BGreen in forum mel PIC BASIC Pro
    Last Post: - 25th May 2007, 16:35
  4. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  5. Serin and TMR0
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 17th May 2006, 15:58
