PWM using a 16F873
Results 1 to 10 of 10
    Dec 2007
    Toronto, Ontario
    Hi again(to myself),
    I must have mistaken this forum for a place where answers are pleantifull OR this is mostly a programming based group. BUT for anyone who is interested in what I was trying to accomplish, it is possible to drive the L293 enable pins with PWM from a pic. I kinda hoped that some guru could have helped me regarding PWM frequencies and possible code EXAMPLES as I'm definately not the first to do this.
    As they say, it's easy if ya know how !
    John.
    Don't forget that you are asking Hardware related questions on a forum dedicated to a Programming Language.
    I'm sure there are people here that can answer the question, but many of them only check the forum every few days or weeks.
    It's only been 5+ hours since the first post.
    Me, I'm a software guy. Can't help.
    Not to mention that there are a lot of time zones and not everybody is on your sleep schedule.
    But like DT said, there's a lot of people around who are good with PWM'ing 2 motors bidirectionally, which without some sort of method of counting rev's or speed, good luck trying to get the thing to run straight.
    The big thing I can suggest... Get yourself 4 LEDs, wire them up in 2 pairs of opposing parallel before getting PIC driven MOSFETs connected to motors.
    That way you can play with PWM (no matter what your method, software, hardware, off-chip driven, etc), watching LED brightness, and the opposing parallel pairs of LEDs will give you a visual indication of both direction and relative speed, with practically no chance of blowing up a PIC.
    Gixxer, I built this circuit some years ago. There are 2 such circuits. Each has a pwm channel connected to the "F" terminal and a couple of direction bits associated with it. The reason for 2 direction bits? They set the output to either battery or to ground state. for braking. This circuit is used with a 16F876 which has 2 pwm circuits available. The completed circuit runs 2 motors, forward and reverse with 10 bit pwm values.
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM: Vernacular/Function (Newbee)
    By TerryN in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 17:58
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
