door bell , detect activation
Results 1 to 12 of 12
    Quote Originally Posted by flipper_md View Post
    Hello all
    here I come with my very low skills in electronics, to learn stuff that my brain can't compute
    I have installed a doorbell downstair, but it doesnt ring loud enought. So I taugh I would make a clever doorbell chime/lights with a PIC brain for upstair, as I don't really wan't to hear a loud thing all the time.
    So I extended a wire upstair, thinking I could tap into to signal serially just adding a resistor(it's 12v). uhhh.
    http://www.picbasic.co.uk/forum/atta...1&d=1201800699
    But then I realized I would never get anything from that setup, unless I would tap into the line serially with a relays.
    So I wonder know, is there a *simple*, electronic way(else than a relay) to get a 5v signal from that setup??
    Some kind of ghost current detection?
    thanks to the knowedgeables!
    Dom
    Wireless doorbell from Walmart or something... $10, runs for a couple of years off 2 AA's, range of a 100 feet or so. Mine was a bit loud, muffled it with duct tape internally (after all, what CAN'T duct tape do). And it has an on/off switch when I just don't want to listen to it.
    Now THAT is simple.
    Now THAT is simple.
    But if you want to learn electronics, try a voltage divider.
    http://www.pbpgroup.com/modules/wfse...p?articleid=25
    Italy
    Try that.
    (Click to enlarge the picture)
    Optocoupler Datasheet:
    http://www.vishay.com/docs/83675/sfh620.pdf
    Best regards,
    Luciano
    Jul 2007
    Great,
    I'll see what I can do with opto or voltage divider(Once I grab components to try)
    and skimask, it's just a personnal choice but my life rule is away from wireless
    thanks guys for ur time!
    Dom
    Dom
    Don't get me wrong...I'm all about over-designing, over-engineering something, anything But some things...a guy just has to go out and buy...
    Hi flipper_md,
    Here is a trick I learned here, cheap, simple, in a word elegant: use an LM78L05 regulator.
    the input goes to your 12v+ wire ground to 12v - and output is your 5V +. It is a TO92 case device, perfect as an input reducer for a PIC . Must rectify to use,not for A/C
    Bombay, India
    I read somewhere that almost all problems can be fixed by either duct tape or a helping of WD40. Now if things were really that simple.....
    JF
    JF
    Of course it's not always that simple...You forgot the 48oz drill hammer!
    Jul 2007
    AHah
    i'm a big fan of duct tape too. Two in the car, one in the trailer, one in the house...just so handy and easy to understand
    Hey Joe S, I'll give a try to your idea, but actually I'd like to be able to tap in the signal like a spy, not having access to the ground signal.
    Rectifying the current sound interresting doh! If I tap 2 diodes to the thing, maybe I can get some DC current trace thru a wire??
    I'm really not a big fan of AC =)
    AHah
    Yeah, neither was Edison . . .
    Italy
    Please don't kill an elephant.
    http://en.wikipedia.org/wiki/Topsy_(elephant)
    Best regards,
    Luciano
  1. Detect fast movement using photodiode
    Last Post: - 22nd November 2008, 14:07
  2. Replies: 1
    Last Post: - 7th November 2007, 20:36
  3. Possible to detect I2C Device?
    Last Post: - 30th March 2007, 10:13
  4. USART 9 bit receiver with address detect
    By meldavia in forum Serial
    Last Post: - 29th October 2006, 02:14
  5. Detect baud rate
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 21:10
