SMT transistors
Results 1 to 4 of 4
Thread: SMT transistors
    Mar 2004
    Default SMT transistors
    I know this may at first seem off topic,but can someone tell me what SMT transistor will make a good substitute for a TO92 2N2222 ?
    I need to use them with a PIC12F675.
    Thanks and regards
    Sam
    Try FMMT491, FMMT493, FMMT619, FZT651 etc etc
    You’ll probably find the DTC114E is a real cutie, with its integral Resistors you can connect it directly to the PIC’s pin.
    Mar 2004
    Thank you very much Melanie!
    That's the info I needed.
    Sam
    I use often this BC817-16 in sot23 package. Depending of your need may i suggest you to use digikey web site. Simple and easy to find there. since you'll probably need an SOT-23 package try a search with NPN SOT-23 and see what is the most appropriate for your need.
    regards
  1. SMT prototyping/DIY reflow ovens
    By forgie in forum Off Topic
    Last Post: - 6th November 2012, 11:24
  2. SMT reflow oven - Argos £13.24
    By HankMcSpank in forum Off Topic
    Last Post: - 7th August 2009, 18:17
  3. Parallel Transistors?
    By George in forum Off Topic
    Last Post: - 6th April 2009, 16:25
  4. Sort of OT, SMT cap...which side is negative
    Last Post: - 28th January 2006, 14:55
  5. SMT soldering
    Last Post: - 30th October 2005, 21:45
