Problems with driving external EEPROM M24256
Results 1 to 19 of 19
    Quote Originally Posted by kindred22 View Post
    how to read and write data on the internal eeprom of 16f877a?
    is there a need of interrupt disable?
    because when i program a reading data it will out only on the lcd a 0 using the command READ passing through a variable, and on to the lcd..
    on the writing data will cause an infinite loop...
    thank you...advance
    And yet again...where's the code?
    Silly, it's still in the phillipines!
    Cool
    OF COURSE! What was I thinking! That's where it's been all along...
    And I would've gotten away with it too if it hadn't been for you meddling kids...
    Nov 2007
    Bohol, Philippines
    Default Code!
    sorry i didn't put out the code...
    portb=0
    trisb=0
    aa var byte
    bb var byte
    eeprom 2,[0]
    aa=4
    write 2,aa
    read 2,bb
    if bb=4 then
    portb.0=1
    that is my code!!!
    using 16f877a did not light portb.0
    using 16f84a light...
    is there any prob with my code?
    tnx...
    portb=0
    trisb=0
    aa var byte
    bb var byte
    eeprom 2,[0]
    aa=4
    write 2,aa
    read 2,bb
    if bb=4 then
    portb.0=1
    that is my code!!!
    tnx...
    How many times are you going to double post?
    Once is more than enough from the multiple personalities.
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Replies: 1
    Last Post: - 28th January 2010, 22:15
  3. Replies: 5
    Last Post: - 24th June 2009, 03:01
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
