parallax rfid reader module interface with PC
Results 1 to 3 of 3
    Jan 2008
    Default parallax rfid reader module interface with PC
    I am doing an interface with the PC and the parallax RFID reader module through PIC 16F877A. The program interface in the PC is Visual Basic 6(VB6) . I think there is something wrong with my Visual Basic codings. When i scan the RFID tag , the VB6 will capture the data from the PIC. Then it will search the database for the matching ID. IF found , the label box will put Found It. The porblem is that when i scanned the matching RFID ID tag , the VB6 program will put Not Found in the label box and the program will hang. When the MSComm1.output = Chr$(255) & Chr$(modenumber) command line is deleted, when the RFID tag is scanned , the program can find the matching data in the database. Is there any problem with my codings ? Below is the vb6 program code.
    Private Sub Form_Load()
    MSComm1.CommPort = 1
    MSComm1.Settings = "2400,N,8,1"
    MSComm1.RThreshold = 10
    MSComm1.SThreshold = 1
    MSComm1.InputLen = 0
    MSComm1.PortOpen = True
    MSComm1.DTREnable = False
    MSComm1.RTSEnable = False
    End Sub
    Private Sub MSComm1_OnComm()
    Dim buffer As String, Criteria As String
    Dim IDFound As Boolean
    Dim modenumber As Integer
    If (MSComm1.CommEvent = comEvReceive) Then
    buffer = MSComm1.Input
    picBox.Print buffer & " " & Time() & " " & Date
    End If
    IDFound = False
    modenumber = 0
    Criteria = "ID =" & "'" & buffer & "'"
    datIDTAG.Recordset.FindFirst Criteria
    MSComm1.OutBufferCount = 0
    Do While datIDTAG.Recordset.NoMatch = False
    modenumber = 1
    lblNum.Caption = "Found It. " & modenumber
    IDFound = True
    datIDTAG.Recordset.FindNext Criteria
    Loop
    If IDFound = False Then
    lblNum.Caption = "Not Found. " & modenumber
    End If
    MSComm1.Output = Chr$(255) & Chr$(modenumber)
    End Sub
    Plz help me to solve this problem.Thanks.
    May 2005
    Minnesota
    Default MSCOMM and RFID reader
    Jonil22,
    Try adding MSCOMM1.InBufferCount = 0 at the end of the OnCom event.
    You may want to close the port as soon as you have your data.
    B
    Jan 2008
    dear cooksydesign,
    i have tried what you recommend me to do but the program still cannot run whenever i put the MSComm1.ouput line. So sorry for the late reply.
  1. TTL magnetic card reader interface ith PC
    By attabros in forum Schematics
    Last Post: - 24th February 2016, 07:04
  2. Parallax RFID Reader code example
    By dan-tron in forum Code Examples
    Last Post: - 19th April 2013, 22:16
  3. Parallx rfid reader module interface with PC
    By jonil22 in forum mel PIC BASIC Pro
    Last Post: - 31st January 2008, 08:50
  4. Serial interface with RFID reader
    By brid0030 in forum Serial
    Last Post: - 23rd January 2007, 06:23
  5. PIC16F877 to RFID Module Serial Interface
    Last Post: - 17th May 2005, 06:03
