Automatic Toilet Flusher
Results 1 to 40 of 99
    Jul 2007
    Well that's a good idea so
    better yet I made a video
    COOL!
    What was the problem before?
    Jul 2007
    Thanks, the reason it wasn't working was because pin 3 was not going to positive so for some reason the led kept being on but once I supplied the 5 volts + to pin 3
    it worked.
    Thanks, Good info.
    Apr 2006
    New Hampshire USA
    Question pin 3 or pin 1
    Quote Originally Posted by Techbuilder View Post
    Thanks, the reason it wasn't working was because pin 3 was not going to positive so for some reason the led kept being on but once I supplied the 5 volts + to pin 3 it worked.
    Hi Techbuilder,
    Do you mean pin 3, or pin one (1) to plus (+)?
    <IMG SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2351&stc=1&d=120266867 7">
    -Adam-
    Jul 2007
    Yeah actually your right
    it was pin 1 that I supplied the + to because pin 3 goes to ground
    Sorry my mistake
    Jul 2007
    IRLED1 var PORTB.0
    Servo var PORTB.1
    TRISB=%00000001
    Loop:
    If IRLED1 =1 then
    Pulsout 0,130
    pause 10
    pulsout 0,150
    pulsout 0,150
    Goto Loop
    This is the code I made do you think this might work?
    Basically I want it to read the input and if the proximity sensor is activated then have it move the servo all the way to the right or left.
    To find the center of the servo
    I knew that dead center was 1.5ms and since I am using a 4mhz crystal the time interval of PULSOUT is in units of 10 us.
    So I used this equation to find my pulse
    1.5ms = 1500us
    and then 1500/10= 150
    and clockwise is 1.3ms so I did the same equation for that
  1. Automatic 240V / 110V selector
    Last Post: - 13th October 2008, 01:33
  2. LCD automatic management?
    Last Post: - 26th September 2008, 12:24
  3. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 08:57
  4. Automatic turn off
    By AMay in forum Schematics
    Last Post: - 6th February 2006, 13:31
