Automatic Toilet Flusher
Results 1 to 40 of 99
    Jul 2007
    Cool I got it working!!!!
    Yay now I am one step further to completing the automatic toilet flusher.
    Thanks Pic_User
    Apr 2006
    New Hampshire USA
    Thumbs up Keep going....
    Quote Originally Posted by Techbuilder View Post
    Thanks Pic_User
    Great news Techbuilder,
    Can you give us your impressions of the results?
    Do you get the same range as the web site 15 cm (5.9”)? Reflected..
    Does the “target” surface color / shininess make a difference?
    Does ambient light clobber it?
    How much range if you detach the IR Emitters, put extension wires on them, and point them at the sensor (beam break)? Like across a door way...
    -Adam-
    Jul 2007
    Well that's a good idea so
    better yet I made a video
    COOL!
    What was the problem before?
    Jul 2007
    Thanks, the reason it wasn't working was because pin 3 was not going to positive so for some reason the led kept being on but once I supplied the 5 volts + to pin 3
    it worked.
    Thanks, Good info.
    Apr 2006
    New Hampshire USA
    Question pin 3 or pin 1
    Thanks, the reason it wasn't working was because pin 3 was not going to positive so for some reason the led kept being on but once I supplied the 5 volts + to pin 3 it worked.
    Hi Techbuilder,
    Do you mean pin 3, or pin one (1) to plus (+)?
    <IMG SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2351&stc=1&d=120266867 7">
    -Adam-
  1. Automatic 240V / 110V selector
    Last Post: - 13th October 2008, 01:33
  2. LCD automatic management?
    Last Post: - 26th September 2008, 12:24
  3. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 08:57
  4. Automatic turn off
    By AMay in forum Schematics
    Last Post: - 6th February 2006, 13:31
