Automatic Toilet Flusher
Results 1 to 40 of 99
    Apr 2006
    New Hampshire USA
    Smile Google....
    Quote Originally Posted by Techbuilder View Post
    Hey Pic_User or anyone
    Is it difficult to interface the that link that you gave me to a pic?
    All I want it to do is when it comes in contact, to rotate the servo all the way to the right or all the way to the left.
    Hi Techbuilder,
    search Google:
    IS471FE
    Find this (second hit):
    http://document.sharpsma.com/files/L...ce-opic_AN.pdf
    On this Sharp application note:
    Light Detecting Device-opic
    Search for:
    IS471FE
    Page 5 tells us:
    the parameters of the IS471FE
    Page 24 shows us the internal / external hook-ups of the IS471FE
    <IMG SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2326&stc=1&d=120200443 9">
    Mostly it looks like it will operate with 5V DC input.
    It has “open collector” output.
    It has a built in 10k “pull-up” resistor.
    so it LOOKs like you could use a circuit like this:
    <IMG SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2325&stc=1&d=120200428 1">
    Thanks to:
    Garrett Hamilton–Smith, Raihan Khondker, and Will Norris,
    School of Information Technology and Engineering, University of Ottawa
    http://www.g9toengineering.com/AllSa...dproximity.htm
    -Adam-
    Jul 2007
    Quote Originally Posted by Pic_User View Post
    Hi Techbuilder,
    search Google:
    IS471FE
    Search for:
    IS471FE
    Page 5 tells us:
    Thanks to:
    -Adam-
    Thanks, would it be hard to compile a code to detect using this method?
    Apr 2006
    New Hampshire USA
    Default like a push button
    Hi Techbuilder,
    You could consider the module like a push button. Your program would need to watch for a low or 0 (zero) to know someone / some thing had come close to the sensor module.
    -Adam-
    Jul 2007
    Ohh ok
    I get it
    So if I want to change the range to about 6 inches would that be done by changing the resistance to the IR leds?
    Apr 2006
    New Hampshire USA
    That web page said "approximately 15cm". I had to use an on-line calculator because I am an old phart, and it said almost 6 inches (5.9").
    Jul 2007
    Cool
    thanks I appreciate it
    and I appreciate everyone else helping me
    Well I am going to order that Sharp IS471FE and then write a program
    well try and then post my progress.
    Thanks everyone
    Apr 2006
    New Hampshire USA
    Lightbulb test as you go
    Techbuilder,
    How about:
    You order the Sharp IS471FE and start the program right away, while you are waiting.
    You can substitute a switch.
    When the IS471FE gets there you can just add it.
    This is actually a good way to build and test as you go.
    -Adam-
  1. Automatic 240V / 110V selector
    Last Post: - 13th October 2008, 01:33
  2. LCD automatic management?
    Last Post: - 26th September 2008, 12:24
  3. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 08:57
  4. Automatic turn off
    By AMay in forum Schematics
    Last Post: - 6th February 2006, 13:31
