Automatic Toilet Flusher
Results 1 to 40 of 99
    Mar 2006
    Pennsylvania, USA.
    Take a look at the Parallax website, they have some tutorials that you can download. One of them gives an example of using the Basic Stamp freqout command to drive an infrared emitter, and then collecting the signal if it is reflected back by an object in close proximity. The neat thing about their approach is that they demonstrate that by changing the modulated frequency you can determine a relative distance to the object. So, no one in the room, no reflection, someone approaches the toilet, wait, they leave, then gosub flush. I would suggest that you also monitor the temperature of the water feed line into the toilet. If unused, the water temperature will be close to room temperature. If you sense a drop in temperature while the infrared sensor senses someone close, or shortly thereafter, then that person flushed, (your fresh water should be colder,) and you don't waste any water flushing a second time.
    I'm sure that the infra-red information is in the 'Toddler' robot section of the Parallax site, and I think it appears in a few other places. You'll have to experiment to find the maximum range. Radio-Shack now carries some Parallax sensors, they have a passive infra-red motion sensor, I believe that it's only seven or eight dollars. Might be worth a look.
    Good luck!
    Jerry.
    If your oscilloscope costs more than your car...
    Jul 2007
    That's kind of want to do
    What I want is just an IR sensor that reads when a hand has been passed by it and turns the servo all the way to the left (or right) and flushes the toilet.
    I made a drawing
    Apr 2006
    New Hampshire USA
    Smile Infrared Proximity Sensor...
    Some ideas about this here:
    http://www.g9toengineering.com/AllSa...dproximity.htm
    -Adam-
    Jul 2007
    Quote Originally Posted by Pic_User View Post
    -Adam-
    This is exactly what I am talking about
    but how hard would it be to interface with a PIC?
    Mentor, Ohio
    Smile
    Hi Techbuilder,
    I really like your determination to build something. BUT, if they won't flush the toilet, what makes you think they'll wave their hand in front of a motion sensor that'll cause the toilet to flush? Here's an idea---get an under the carpet pressure pad and hook it up to an 12Fpic. Get a pretty pink toilet mat to pu over the pad. The system will sit in a WHILE/WEND loop until the USER is off the pad then it activates your solenoid to flush the toilet. Oh my gosh. I can feel the idea juices starting to flow. Is it exciting. Keep going and let us know your progress. I love this idea stuff.
    HTH,
    BobK
    Jul 2007
    I asked them would you at least wave your hand
    and they said they would.
    We don't have a carpet
    Plus I think the way I drew it would be the best solution
    to get them in the habbit
    Yelling does nothing
  1. Automatic 240V / 110V selector
    Last Post: - 13th October 2008, 01:33
  2. LCD automatic management?
    Last Post: - 26th September 2008, 12:24
  3. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 08:57
  4. Automatic turn off
    By AMay in forum Schematics
    Last Post: - 6th February 2006, 13:31
