pic basic pro (novice user)
Results 1 to 2 of 2
    f6ggy's Avatar
    f6ggy Guest
    Default pic basic pro (novice user)
    in order to program a synthetizer on a station radio hamradio, it is necessary to send in series (MSB LSB) two numbers, one on 10 bits (ex 567 into binary) and the other on 7 bits (ex 4 into binary) how declarer these two variables because I will want to safeguard them in eeprom and surout to send them on porta.0 in s?rie thank you for your assistance
    Well, in PBP there are only three kinds of variables, bit, byte and word. If it's more than one bit, you use a byte. If it's more than 8 bits, then you use a word. Words can easily be broken into two bytes, and then saved and/or recalled from EEPROM.
    You didn't say if your sythesiser requires serial input in the form of sychronous or asynchronous data. This determines if you use something like SEROUT or something like SHIFTOUT. With SHIFTOUT you can easily preset the number of bits to whatever length you require. With SEROUT it's not easy to send data other than 7 or 8-bits at a time. How this is approached will depend on your synthesiser's actual requirements.
    Melanie
  1. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 14:18
  2. I want to buy PIC BASIC PRO...
    By simransingh in forum General
    Last Post: - 30th October 2007, 18:13
  3. PIC BASIC or PIC BASIC PRO
    By kirkmans in forum USB
    Last Post: - 20th April 2007, 01:52
  4. Replies: 5
    Last Post: - 17th January 2006, 20:26
  5. How to use 93C46 Type EEPROM using PIC Basic PRo
    By in forum mel PIC BASIC Pro
    Last Post: - 1st April 2003, 05:07
