Saving RFID Data
Results 1 to 27 of 27
    Quote Originally Posted by Pesticida View Post
    Hi Skimask,
    What you mean with out of bond!?
    Did you mean when I receive a wrong character.
    Regards Pesti
    What happens if you get a character that you weren't expecting? One with a value too low or too high...
    For instance:
    Daten[N]= ((Daten[N]-$30) *10) + (Daten[N-1]-$30)
    What happens if the value in 'Daten[N]' or 'Daten[N-1] is $30? is $20? is $0?
    Ok this is a very good argument ! :-)
    Is good that you have warnning me I forgot this :-(
    I think that i should the Data discard !
    Or I think wrong !?
    Something like this:
    Bad_Data var bit
    Bad_Data = 0
    Data_Check:
    for N = 0 to 13
    If Daten(N) < $30 then Bad_Data = 1 : Daten(N) = $30
    Next N
    Select case Bad_Data
    case 0 ' it's all ok
    for N = 13 to 1 step - 2
    Pause 5
    next N
    case 1 ' no good :-)
    Bad_Data = 0
    Goto Warning or something like that
    end select
    If I have Daten[N] = $30 this is not bad while $30-$30 = 0
    Regards Pesti
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
