Saving RFID Data
Results 1 to 27 of 27
    Hi
    Yes I read the book and i now that hex is to convert decimal in hex !
    I think i have a serial problem i have read more rfid chips and i receive always the same serial.
    Thank you
    Regards Pesti
    Hi
    Yes I now what is happen the rfid send ascii,the pic receive the ascii and convert all the characters in decimal values 0 is 30 ,4 is 34 and so on.
    Than I have more than 8 bytes I have 16 bytes.
    I must now convert the decimals in hex,while i need hex data.
    I try with hex but dont work!
    Regards Pesti
    Quote Originally Posted by Pesticida View Post
    Hi
    Regards Pesti
    Re-Read Post #16...then refer to your PBP on the proper use of SERIN/SEROUT/(etc) available modifiers and you WILL have your answer. I understand what you want, but I'm not going to give you the answer you need because you have all of the resources you need to get that answer...and you might learn something.
    Sorry Skimask!
    When I have 30 34 30 31 thats mean i need a modifier with 4 to have 04 and 01.
    Regards Pesti
    Sorry Skimask!
    Regards Pesti
    Yes, I know...and your answer awaits...
    Hi,:-)
    I Use this:
    DEBUGIN [WAIT("E0"),dec4 Daten[14], dec4 Daten[13], dec4 Daten[12], dec4 Daten[11], dec4 Daten[10], dec4 Daten[9], dec4 Daten[8],dec4 Daten[7], dec4 Daten[6], dec4 Daten[5], dec4 Daten[4], dec4 Daten[3], dec4 Daten[2], dec4 Daten[1],dec4 Daten[0]]
    While DEBUGIN more fast is,but i have now more bytes this is not what I want.
    And that with Raw data what you have mean is working: :-)
    HSEROUT ["E0",Daten[14], Daten[13],Daten[12], Daten[11], Daten[10], Daten[9], Daten[8], Daten[7], Daten[6], Daten[5], Daten[4], Daten[3], Daten[2], Daten[1],Daten[0],13,10]
    What is if I use instead dec4 hex modifier,can I reduce my bytes!?
    Thank you Skimask
    Regards Pesti
    This is the Solution :-)
    DEBUGIN [WAIT("E0"),Daten[13],Daten[12],Daten[11], Daten[10], Daten[9],Daten[8], Daten[7],Daten[6], Daten[5], Daten[4], Daten[3], Daten[2], Daten[1], Daten[0]]
    Pause 50
    for N = 13 to 1 step - 2
    Daten[N]= ((Daten[N]-$30) *10) + (Daten[N-1]-$30)
    Pause 5
    next N
    High Led_Tag
    Gosub ReadTime
    Gosub Read_BCD
    HSEROUT ["E0",hex2 Daten[13],hex2 Daten[11],hex2 Daten[9],hex2 Daten[7],hex2 Daten[5],hex2 Daten[3],hex2 Daten[1],13,10]
    Regards Pesti
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
