serial communication time
Results 1 to 28 of 28
    Jan 2008
    Selm, Germany
    Default Precise Problem definition
    Ok. To make it clear I want This:
    http://www.sportdevices.com/ignition/ignition.htm
    but want to do that myself AND by using Picbasic Pro (Full version 2.5). I don´t want to write Asm because I´m unable to do so.
    Although I know this could be done with 1 simple PIC I´m willing to take 2 of them or 3 if necessary for Picbasic Pros sake.
    Those smart Guys that programmed ignitions don´t even give you the ASM code, only Hex.
    Further I need this circuit and software etc. modified for different engines . For that I bought the PBP software.
    I know You Guys could programm something like I need in 5 minutes or less but I need something in simple structure so I can handle the software and necessary changes.
    My actual problem is the fact that my serial pic to pic communication is far to slow AND the com routine seems to delay the interrupt action by about 1ms which is inacceptable.
    Hope this made everything clear.
    thanks for your interest.
    In my mind...short and simple answers...
    High speed PIC's could handle the work...it's all about the guy behind the keyboard
    High speed anything don't work too well in the automotive environment...it's all about the guy designing the filters.
    9600 baud...not so much...as stated before. You want data transmitted every .4ms . Not going to happen at 9600 baud, I don't care how you program it, unless you want to start dropping bits and sending 3 bits instead of 8. Must go with much higher speed as stated earlier.
    You don't want to learn or write in assembly? Well, that's probably not going to happen either. PBP's built-in 'ON INTERRUPT' is designed in such a way that latency is practically unavoidable in a lot of situations. Using DT's Fast Interrupts isn't that hard, and yes, it does require you to learn a little bit about ASM, not much though.
    In my mind, any serious ignition work is best suited for a different processor, maybe a dsPIC...not that a PIC couldn't handle it...with the right programmer behind the keyboard. Personally, I think you're playing with matches in a gas fume filled room. One ignition event just a bit early, there goes the intake manifold, a whole load of events a bit early, now you've got 8 pistons that could double as doughnuts and con-rods that could do double duty as horseshoes.
    Jan 2008
    Selm, Germany
    Default serial communication speed? Parrallel communication !
    Hi .
    Ok maybe I´m not software-smart enough to get my data sending/recieving problem as fast as needed.
    So I try to switch to parallel communication.
    I like the instruction:
    PortB = VAR (byte)
    the only problem is the fact that I need Portb.0 for the external interrupt so I will take the PIC16F873 which has more pins. Still need the ZIF socket for my programming adapter.
    I will tell how that works.
    To Skimask:
    yes you are right about your detonation assumptions.
    Know a bit about engines myself : http://www.davidpower.de/fotos_mot.htm
    Quote Originally Posted by Mugelpower View Post
    I don't think it's so much serial vs. parallel as it is the fact that you've got to SPEED up the serial quite a bit, which is entirely doable, or switch over to a CAN based type network, which again, with the newer PICs, entirely doable.
    Point taken. Looks like a bit of a fun place to work there! Wish I could read German(?)
    Jan 2008
    Selm, Germany
    Question Is Debug an alternative?
    in a post i read something like this:
    Define Debugin_Reg portc
    Define Debugin_Bit7
    Define Debugin_Mode 0
    Define Debugin_Baud 115200
    The baud rate seems to good to be true. is that possible with a 4 Mhz crystal , or maybe a 10 Mhz ? By the way I don´t get my Pic 16F628A-20 to work with max Speed regardless of capacitors. Tried several 20 Mhz crystals: No Go! tried several 10 Mhz crystals with different capacitors (27 pF-yes ,22pF-yes, 15pF-yes , 12 pF-no) and they worked.
    What could be wrong?
    Jan 2008
    Selm, Germany
    Default portc?
    oh yes what does Portc mean in the upper post,
    why not Portc.0 or something?
    Remember every piece of wire at radio frequencies exhibits the properties of inductance and capacitence, and the reactance of both. Which means the wire acts as both a coil and a capacitor.
    Might be you have too much wire attached to the Xtal lines, too many sharp bends in those wires, too low impeadance due to resistance path between pins somehow, If you forget to change the config fuse from XT to HS then insufficient power to OSC. Try using a resonator without additional caps and keep those wires as short and straight as possible.
    JS
    Jan 2008
    Selm, Germany
    Question Serial com with DEBUG
    Thanks for your Help so long Guys.
    As you know I will do as You tell and try. So I bought everything I need to try parallel com between pics but at first I will give "Debug" a try because its so fast (I read about that)
    Sending (with all the Defines at Baud rate 9600)
    CNT Var Byte
    Debug [cnt]
    Recieving (same Definitions)
    Debugin ; cnt
    LCDOUT $FE02 `something like that, worked before
    LCDOUT $FE80 "CNT=" , CNT
    I´m not absolute shure about the code BUT
    The LCD Display recieves something but only one Element which changes when changing the Input frequency
    It shows CNT=§ (its the german symbol for "Divide" I dont have it on my keyboard)
    or CNT=A (but only half symbol height and square)
    This shows the transmission works, its just like different languages.
    When I use Serout/Serin everything works fine
    then it shows "CNT=146" for example whith input freq 146Hz .
    There must be more about Debug/Debugin
    I tried changing the Var defines from byte to dec which changed the display from rubbish to rubbish .
    I thought if i´m sending a Var frompic to pic then it doesn´t change. Obvious it does.
    What I´mmissing?
    I´m showing the precise program code today in the evenig when I´m back home.
    I need just a simple example for sending a byte by debug from pic to pic.
    Oh yes I dream of baud rate 120000 or something....
  1. Replies: 5
    Last Post: - 20th March 2006, 02:34
  2. Bootloader,MCSP and Serial communication
    By surfer0815 in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2006, 11:52
  3. Serial Communication using 12F629
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th March 2005, 05:24
  4. Serial communication PIC to PIC help.
    Last Post: - 24th January 2005, 16:45
  5. Replies: 8
    Last Post: - 11th November 2004, 21:08
