polling information in rs-232
Results 1 to 15 of 15
Threaded View
    Feb 2008
    Question polling information in rs-232
    Hi all,
    i'm new to your community and in search of a (probably) simple answer to my problem.
    pardon my inexperience, but to learn i guess the best way is to start asking for help (after doing a big search everywhere; OF COURSE ).
    my problem:
    i have a strip of data from a gps unit in NMEA
    $GPGGA,150126,4521.3660,N,07317.9876,W,1,03,102.3, ,,-032.30,M,,*1D
    i use a 16f877a (to receive it's no problem)
    the problem is that i want to re-send that information ($GPGGA, etc....) every second while i still watch the next incoming data.
    here's a simple example:
    ' This will set the serial port 4800
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 4800
    GPS VAR byte
    char var byte
    ' receive from GPS unit
    Hserin [char] ' <- works!
    GPS = GPS + char '<<<< that part is causing the problem >>>>
    ' send to computer
    hserout [GPS]
    goto main:
    what i really want to achieve is that the part "hserout [char]" would transmit to the PC every second while i still check the incoming "Hserin [char]" from GPS unit
    i know there might be a much simpler way to do this, so i need a bit of your experience please.
    Tried to lower the baudrate, tried with interrupt, etc... the "GPS = GPS + char" cause some garble characters in the receiving process...
    If i use a LOOP in the "hserout [GPS]" i prevent the reception of new data from GPS unit.
    there might be a way while reading the RECREG , but i don't know how....
    Awaiting your help
  1. RS 485 wireless communication
    By Armadus in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 19:30
  2. Displaying Trend Information
    By Mike M. in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2005, 03:21
  3. RS 485 using 16F84A
    Last Post: - 18th May 2005, 14:46
