Synchronizing Xtal Osc
Results 1 to 5 of 5
Threaded View
  1. #2
    My question is, can I stop the oscillator by switching the xtal pin to ground, then turn it back on
    at my opinion, answer is no. it will cause pic to reboot or malfunction or maybe freeze to some adress.
    If want to add text to a video signal, why not using some BOB-3 Video-Text Overaly Module
    http://www.hvwtech.com/downloads/man...ions_Guide.PDF
    or may want you to design your own... have a look over the net, i'm sure there's still IC that mixe 2 signal together without you have to care about synchronise them together like the old STV5730A wich seems to be obsolete or hard to find for now.
    May ST9936 or ST9937 be a good start for easy solution. Seems also hard to find them too.
    regards
  1. 16F877A with 20MHz XTAL not working?
    By ustredna in forum mel PIC BASIC Pro
    Last Post: - 19th August 2011, 16:04
  2. Internal vs. external osc for comms
    By mtripoli in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 15:58
  3. Replies: 4
    Last Post: - 9th October 2009, 09:01
  4. Replies: 2
    Last Post: - 7th October 2009, 01:06
  5. Define osc 1
    By ronsimpson in forum mel PIC BASIC Pro
    Last Post: - 1st October 2009, 07:35
