Working bootloader hex on 18f2550
Results 1 to 22 of 22
    Feb 2003
    Sydney, Australia
    Default Got it working !!
    I am a very happy chappie !
    I managed to recompile the bootloader to use alternative LED pins. One thing to be aware of is that there are now two bootloader codebases that Microchip provide. One is the HID bootloader, the other is one that will work with the MPUSB application.
    I tried the HID bootloader, but got some weird results, so instead modified the MPUSB bootloader which uses the custom Microchip driver. This allows me to continue to use the PICDEM FS Demo Board application to bootload my code.
    All good ! Also learned more about MPLAB and C coding than I think I ever wanted to know...
    bill.
    Grrrrrrrrreat! It's always good to have another tool in the toolbox huh?
    Out of curiosity... what kind of problem you got with HIDBootloader?
    Feb 2003
    Sydney, Australia
    Hi Steve,
    I think it was more the PC application would have some issues resetting the PIC after uploading.
    I'll have a try again when I get home as I also locked up the USB ports on my laptop by accidentally connecting the PicKit2 backwards on the ICSP header....
    Luckily they came good after a reboot and I then reflashed the board with the MCPUSB bootloader and we were away !
    I'd actually prefer to use the HID bootloader, so I will see if I can get it to work and let you all know.
    Man, the more I play with this USB stuff the more I love it !!!
    bill.
    Feb 2003
    Sydney, Australia
    Just doing a bit of digging in MPLAB at luchtime and I think I know why it was not working.
    It seems the HID bootloader is a lot bigger than the MCHPUSB one. In MPLAB it uses 2040 bytes of program memory, compared with the 980 used by the MSCHUSB one.
    In my PBP code I had this :
    DEFINE RESET_ORG 800h
    statement to jump over the end of the bootloader, but for the HID version I would need to make that RESET_ORG 1000h.
    Like I said, I will try it when I get home as suddenly things make a lot more sense - I remember I was having issues with the program not working after I had bootloaded it, and then the bootloader failing - which I put down to me locking up the USB ports (which I also did).
    Like I said, I love it, but it needs a lot of brain time !!
    bill.
    Feb 2003
    Sydney, Australia
    Updating the PBP code with
    DEFINE RESET_ORG 1000h ' For Microchip USB Bootloader
    DEFINE INTERRUPT_ORG 1008h ' For Microchip USB Bootloader
    Fixed the issue so I can now use the HID bootloader, which has the source for the Bootloader PC app.
    With the second DEFINE I am not sure if I require it, but I have seen it mentioned in some posts and the Microchip docs actually mention that the Interrupt vectors are moved. It also says that the High and Low priority are on two separate locations, but my code seems to work and its late.
    Tomorrow I will investigate further..
    Till then Happy Pic'n !
    bill
    All you need to make the new HID loader work with PBP is DEFINE RESET_ORG 1000h.
    If you're using both high-pri & low-pri interrupts, then just use the interrupt DEFINEs.
    Example:
    DEFINE INTHAND High-Pri
    DEFINE INTLHAND Low-Pri
    PBP will automatically take care of it for you with ORG RESET_ORG + 8 for the high priority
    jump, and ORG RESET_ORG + 18h for the low priority jump.
    At 0x1008 PBP inserts GOTO High-Pri, and at 0x1018 GOTO Low-Pri.
    If you're not using interrupts all you need is the DEFINE RESET_ORG 1000h.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2003
    Sydney, Australia
    Bruce,
    I have DT_Int running, so will these commands still be needed ? Not sure if it adds these automagically.
    bill.
    Hi Bill,
    All you need is the DEFINE RESET_ORG 1000h. If you look in the DT_INTS-18.bas file,
    you'll see where it's already including the int handler DEFINEs for high & low int handlers.
    So PBP will still place the correct int vector offsets in there automagically for you.
    -Bruce
    tech at rentron.com
    saochu's Avatar
    saochu Guest
    Default thanks all
    i reading and thanks to all some one !
  1. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  2. Replies: 6
    Last Post: - 5th November 2008, 12:30
  3. 18F2550 MCRL/RE3 problem with USB bootloader Microchip
    By Ronald123 in forum mel PIC BASIC Pro
    Last Post: - 24th September 2007, 11:48
  4. Some test hex for a 18f2550
    By f_lez in forum mel PIC BASIC Pro
    Last Post: - 6th October 2006, 15:24
  5. Bootloader + Mainline code in single HEX file
    By dman776 in forum mel PIC BASIC Pro
    Last Post: - 19th May 2006, 23:59
