Controlling Relays
Results 1 to 11 of 11
    Default what value is Keydata if no key pushed ??? good question !
    The value of Keydata is 0 if no key is pressed: here is how I've set that,
    if keyin = nokey then keydata = %00000000
    Thank you for your help.
    Default This is what I am using to send to the relay board
    define osc 4
    INCLUDE "MODEDEFS.BAS"
    CMCON = 7
    serpin var porta.3
    nokey con %11111111
    preamble con %01010101
    synch con 254
    keyin var portb
    keydata var byte
    trisb = %11111111
    trisa = %00010111
    key1 VAR PORTB.0
    key2 VAR PORTB.1
    key3 VAR PORTB.2
    key4 VAR PORTB.3
    key5 VAR PORTB.4
    key6 VAR PORTB.5
    key7 VAR PORTB.6
    na VAR PORTB.7
    findkey:
    clear
    pause 50
    if key1 = 0 then sw1
    if key2 = 0 then sw2
    if key3 = 0 then sw3
    if key4 = 0 then sw4
    if key5 = 0 then sw5
    if key6 = 0 then sw6
    if key7 = 0 then sw7
    if key8 = 0 then sw8
    goto findkey
    sw1:
    keydata = 1
    goto transmit
    sw2:
    keydata = 2
    goto transmit
    sw3:
    keydata = 3
    goto transmit
    sw4:
    keydata = 4
    goto transmit
    sw5:
    keydata = 5
    goto dout
    sw6:
    keydata = 6
    goto transmit
    sw7:
    keydata = 7
    goto transmit
    sw8:
    keydata = 8
    goto transmit
    transmit:
    serout serpin,N2400,[preamble,synch,keydata]
    pause 50
    goto findkey
    All define's must be capitalized (not that it makes any difference in this case)
    Jan 2006
    Istanbul
    1. There is no Key8.
    2. You can send the content of the whole PORTB when a change occurs; may be it would be more convenient but it is up to your choice.
    For example:
    FindKey:
         CLEAR
         KeyData = PORTB
         PAUSE 50
         IF PORTB = KeyData THEN FindKey   'Transmit only if there is at least a (one) change on PORTB.
         SEROUT SerPin,N2400,[PreAmble,Synch,PORTB]
         PAUSE 50
         GOTO FindKey
    This code will transmit the content of the PORTB every time there is a change on PORTB.
    Thus, for instance, if PORTB.0 is 0, it will transmit, and then if it is still 0, it will NOT transmit.
    If PORTB.0 is still 0 and then another change occurs at say PORTB.1 then it will transmit.
    This way, you can handle the process at receiver side.
  1. Replies: 10
    Last Post: - 17th February 2012, 07:19
  2. SMS control for Relays
    By charudatt in forum Code Examples
    Last Post: - 2nd May 2009, 00:08
  3. PIC relays control
    By flipper_md in forum mel PIC BASIC Pro
    Last Post: - 1st October 2008, 16:03
  4. High End Pre with PIC 16F876A
    By abidr in forum mel PIC BASIC Pro
    Last Post: - 8th May 2008, 08:13
  5. Controlling a DC solenoid
    Last Post: - 23rd December 2007, 01:26
