Detecting EOF
Results 1 to 3 of 3
Thread: Detecting EOF
    Default Detecting EOF
    Hello PIC users friends,
    I have an application which reads a .txt file from a USB storage device.
    With Darrel’s help I solved all my problems on dealing with “Big Numbers” (I promisse Darrel this is the last time you will see the label “big_number” or anything similar to it) to extend the “reach” of an old device to higher number of records (I don’t know how to post a link, but look under “Code examples”/ "Retiving 32bit Multiply Result").
    I’m slowly stepping into this magic world of PicBasicPro, my background is not in programming and simple things for the experienced programmer are new to me.
    I did few searches but came empty.
    I am willing to do the work it takes but I’m a little lost when I’m faced with unfamiliar territory. This is one of them.
    I’m planning on working on replacing this “temporary patch” with a newer version and for this I need a way to detect the EOF of a .txt file.
    The questions are:
    1- If I read the .txt data file, with a PIC, byte by byte and look at each byte, when can I say I reached the EOF?
    2- What is the EOF, a special character or a series of characters?
    3- Does anyone know of a way to do it or point me to a place which addresses this problem?
    Nick
    Bombay, India
    The EOF character in TXT files used to be CTRL-Z or 1A(Hex) since the days of CP/M DOS. Nowadays, I don't think this is true. However, you could check for the $1a character in PBP if it is there.
    JF
    Thank you Jerson.
    I will try it and get back with the results.
    Nick
  1. Detecting a pulse
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 13:12
  2. Best choice for detecting water?
    By ShortBus in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 20:18
  3. Dialer detecting end user hookup
    Last Post: - 3rd September 2008, 16:45
  4. Automatically detecting a USB device
    By Demon in forum USB
    Last Post: - 26th July 2006, 01:41
  5. Detecting AC current
    By rhino in forum Off Topic
    Last Post: - 8th July 2005, 21:31
