Thanks a lot , It's agood idea and good information , I will try to read the manual and interfacing from Dos to printer then apply to Microcontroller
with my best regards
Anyone have an idea how to print anything to printer from PC using direct access language PCL5 with any programming language
On the first page of the PCL 5 Printer Language Technical Reference Manual
there is a link to the part 2 of the document. The link does not work in the PDF file.
Below you can find the link to the part 2 of the manual.
Search "LPRINT" in the part 2 of the manual and you will find samples in BASIC and C.
The samples are about HPGL but this will give you an idea how to send the commands to
the printer.
Best regards,
Luciano
Part 1:
http://h20000.www2.hp.com/bc/docs/su...0/bpl13210.pdf
Part 2:
http://h20000.www2.hp.com/bc/docs/su...1/bpl13211.pdf
EDIT: See also these links:
http://h10025.www1.hp.com/ewfrf/wc/d...le=37103#N7571
http://www.dragon-it.co.uk/links/hp_pcl_codes.htm
HP Color LaserJet and LaserJet Series Printers
- History of Printer Command Language (PCL)
http://h20000.www2.hp.com/bizsupport...ectID=bpl04568
