Hi all, I've been trying to get Darrel Taylor's Instant interrupts to work with a 12f675 with no luck. Will they work with a 12f675?
I just get the following error message when I try to compile it:
ERROR: Variable wsave3 position request 416 beyond RAM_END 95.
ERROR: Variable wsave2 position request 288 beyond RAM_END 95.
ERROR: Variable wsave1 position request 160 beyond RAM_END 95.
ERROR: Unable to fit variable RS2_Save
Here is the code I am using:
LED1 VAR GPIO.1
INCLUDE "DT_INTS-14.bas" ' Base Interrupt System
INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts
INT_Handler INT_INT, _ToggleLED1, PBP, yes
INT_ENABLE INT_INT ; enable external (INT) interrupts
PAUSE 1
GOTO Main
'---[INT - interrupt handler]---------------------------------------------------
ToggleLED1:
TOGGLE LED1
@ INT_RETURN
Thanks for any help.
Bill
