LCDout and large filesize 18F452 -> paging problem?
Results 1 to 19 of 19
    Jan 2008
    Finland
    Default LCDout and large filesize 18F452 -> paging problem?
    Howdy,
    LCD is in portD (data=D.0-D.3,RS=D.4,En=D.5)
    TRISD = %01000000 (D.6 is input)
    LCDout interferes pin D.7 as program size grows
    PortD.7 = 1 won't make pin high...
    pulsout portD.7,10000 still works... cannot figure it out.. o:-)
    If I decrease code size, the problem disappears...
    Has anyone faced same kinda problems?
    thnx adv.
    m.
    Post the code...
    Jan 2008
    Finland
    Code is basicly like this:
    DEFINE LCD_BITS 4
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 5
    TRISD = %01000000
    LED VAR portD.7
    --->8---(klipeti-klipeti)--->8--- (lots of stuff)
    Lcdsub:
    lcdout $FE,2,"hello"
    lcdout $FE,C0,"world"
    LED=1 ' This should illuminate the led?
    gosub Lcdsub
    LED=0
    goto Main
    So, if I replace LED=1 with pulsout portD.7,65530 it will blink..
    Otherwise it wont.. BUT..
    If I remove gosubs away, LED=1 will work and it LED will blink..
    Post the code...
    Quote Originally Posted by mara View Post
    It's this that makes it suspicious.
    And which version of PBP are you using?
    Jan 2008
    Finland
    yep, I know.. the code is 500 lines...
    I just tried to save some bandwidth.. o:-)
    > And which version of PBP are you using?[/QUOTE]
    pbpro v:2.50a and uCodeStudio+ v:3.005
    Ok, how about this code, and ONLY this code:
    DEFINE LCD_BITS    4
    DEFINE LCD_DBIT    0
    DEFINE LCD_RSBIT  4
    DEFINE LCD_EBIT    5
    TRISD = %10000000
    LED VAR portD.7
    Lcdsub:  lcdout $FE,2,"hello" : lcdout $FE,C0,"world" : return
    main:  LED=1 : gosub Lcdsub : pause 500 : LED=0 : pause 500 : goto Main
