Rs485 Using Hserin/hserout
Results 1 to 28 of 28
    I have updated everything now, but when I start it up it return the following, no matter if the Slave is running or not.
    <b>
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    </b>
    Could this be a wiring problem or maybe something wrong in my code?
    Thx
    Koossa
    You might try removing the handshaking part.
    Have the slave continuously transmit to the master, and see if you're getting anything.
    If not, then yeah, it could be a wiring problem.
    Or, 10-20 other things.
    Default Background Question
    Hi Koossa,
    Background Question:
    How much distance between master and slave? I am thinking maybe baud rate is too high due to line capacitance, I just had that problem with an ethernet connection, couldn't use 100 had to tell computer to use 10mbs.
    Joe, the distance between my Master and slave is only about 1.5 meters.
    <hr>
    Darrel
    When I remove the handshacking it is working!!
    <b>
    WAITING FOR REPLY..
    REC:1
    WAITING FOR REPLY..
    REC:1
    WAITING FOR REPLY..
    REC:1
    WAITING FOR REPLY..
    REC:1
    WAITING FOR REPLY..
    REC:1
    WAITING FOR REPLY..
    REC:1
    WAITING FOR REPLY..
    REC:1
    </b>
    Do I need to play arround with "pause"?
    See Posts #2 & #5.
    Failing that, post the program as it sits now...
    Skimask
    Thank you for your reply!
    Whith the following code I only get..
    <b>
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    WAITING FOR REPLY..
    </b>
    SLAVE
    <hr>
    <CODE>
    &nbsp;Include "Modedefs.bas"
    &nbsp;DEFINE&nbsp;&nbsp; OSC 4
    &nbsp;DE_OR_RE&nbsp;&nbsp;VAR PORTC.5&nbsp;&nbsp; ' DE and RE Pin of SN75176
    &nbsp;LEDPIN&nbsp;&nbsp; VAR PORTD.2&nbsp;&nbsp; ' LED to confirm PIC is running
    &nbsp;DATARECEIVED&nbsp;VAR BYTE
    &nbsp;
    &nbsp;'======== HSEROUT, HSERIN SETTINGS ==========
    &nbsp;DEFINE HSER_RCSTA 90h
    &nbsp;define HSER_TXSTA 24h
    &nbsp;define HSER_SPBRG 103
    &nbsp;DEFINE HSER_CLROERR 1
    &nbsp;RCIF&nbsp;&nbsp;VAR PIR1.5
    &nbsp;TXIF&nbsp;&nbsp;VAR PIR1.4
    &nbsp;ADCON1 = 7
    &nbsp;TRISC = %10000000
    &nbsp;
    &nbsp;pause 200
    &nbsp;HIGH LEDPIN
    &nbsp;LOW DE_OR_RE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;' Make ready for RX
    &nbsp;PAUSE 4
    &nbsp;hserin 100,Main,[WAIT ("S"),DATARECEIVED] ' Looking for "S0"
    &nbsp;IF DATARECEIVED = "0" THEN
    &nbsp;&nbsp;&nbsp;&nbsp;HIGH DE_OR_RE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' Make ready for RX
    &nbsp;&nbsp;&nbsp;&nbsp;PAUSE 4
    &nbsp;&nbsp;&nbsp;&nbsp;HSEROUT ["R1"]&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' Send R1
    &nbsp;ENDIF
    &nbsp;GOTO MAIN
    </CODE>
    <hr>
    MASTER
    <hr>
    <CODE>
    &nbsp;&nbsp;
    &nbsp;RS232_DEBUG_PIN VAR PORTB.5&nbsp;&nbsp; ' Debugging to PC
    &nbsp;'======== HSEROUT, HSERIN SETTINGS ==========&nbsp;
    &nbsp;
    &nbsp;ADCON1 = 7
    &nbsp;PAUSE 200
    &nbsp;HIGH LEDPIN
    &nbsp;
    &nbsp;HIGH DE_OR_RE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; ' Make ready for TX
    &nbsp;PAUSE 4
    &nbsp;HSEROUT ["S0"]&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp ; ' Send "S0"
    &nbsp;PAUSE 4
    &nbsp;SEROUT RS232_DEBUG_PIN,N2400,["WAITING FOR REPLY..", 13, 10] ' DEBUG TO PC
    &nbsp;hserin 100,Main,[WAIT ("R"),DATARECEIVED]
    &nbsp;SEROUT RS232_DEBUG_PIN,N2400,["REC:",DATARECEIVED, 13, 10] ' DEBUG TO PC
    GOTO Main
    </CODE>
    <hr>
    Any idea what I am doing wrong?
    Thank you very much!!!!
    Koossa
    It takes at least 87.5ms for each of those SEROUT debug statements to execute at 2400 baud. My guess is that both sides are getting sync'd up into not receiving each others inputs and they both end up missing each others outputs.
    How about getting rid of them and try to use LEDs to see if either program is getting what it should? Maybe use a couple of switches on one, and LEDs on the other, and get one PIC to follow the other PIC.
    Failing that, how about this:
    SLAVE
    DE_OR_RE VAR PORTC.5 ' DE and RE Pin of SN75176
    LEDPIN VAR PORTD.2 ' LED to confirm PIC is running
    DATARECEIVED VAR BYTE
    RCIF VAR PIR1.5:TXIF VAR PIR1.4:ADCON1 = 7:TRISC = %10000000
    pause 200:HIGH LEDPIN
    hserin 10,MAIN,[WAIT ("S"),DATARECEIVED] ' Looking for "S0"
    HSEROUT ["R1"] ' Send R1
    hserout ["RZ"] ' Send something to signify SOMETHING received
    GOTO MAIN
    MASTER
    RS232_DEBUG_PIN VAR PORTB.5 ' Debugging to PC
    PAUSE 200:HIGH LEDPIN
    HSEROUT ["S0"] ' Send "S0"
    GOTO Main
  1. RS485 splitter
    Last Post: - 30th August 2009, 06:04
  2. RS485 Vs Wireless (TWS-434A)
    By koossa in forum Off Topic
    Last Post: - 11th April 2009, 12:40
  3. Using 16f676 with comms
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2005, 20:01
  4. RS485 - ibutton network
    By ccsparky in forum mel PIC BASIC Pro
    Last Post: - 6th June 2005, 21:48
  5. RS485 Extender
    By SergioRM in forum mel PIC BASIC Pro
    Last Post: - 28th December 2004, 00:09
