lcd
Results 1 to 4 of 4
Thread: lcd
    mississippi's Avatar
    mississippi Guest
    Default lcd
    I wrote a program like in the manual for lcd.
    I have a 16 char 1 line lcd display.
    I use the 4 line connection.
    When I display the text I only see the first 8 characters.
    The characters for 9 to 16 are not visible.
    What is wrong?
    Hi mississippi,
    Most 1x16 displays are actually a 2x8 with both "lines" next to each other.
    Try doing this...
    LCDOUT $FE,1,"Line 1 ",$FE,$C0,"Line 2 "
    HTH,
        Darrel
    anj's Avatar
    anj Guest
    Gday Darrel
    Helped me.
    I had an old 1x16 that only showed 8 chars.
    Could never get it to work properly till now.
    Andrew
    Oct 2003
    holland
    Darrel,
    That was the problem.
    I chose 2 lines and I put the data to line 2 and now I can read 16 char's.
    Thanks.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. LCD will not start
